edlebrock 600cfm
Old Sep 10, 2006 | 09:17 AM
deadman's Avatar
Car: 89 camaro
Transmission: 700r4 w/ shift kit
Axle/Gears: stockers
edlebrock 600cfm
i have a 305 with an edlebrock 600cfm set at the setting of air and fuel both at 2 turns out from closed because that is the setting the carb came with. can someone tell me what the setting should be? or a close guess. as of right now the car runs ok but a little more would help.
Old Sep 10, 2006 | 11:35 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
thats pretty close.
the best way to adjust the idle mixture would be with a vacuum gauge. allow the car to fully warm up, then adjust each screw, one at a time, until you get the highest reading on the vacuum gauge.
make sure you use manifold vacuum though, the vacuum port on the right side(drivers) facing the front.
...whats your timing look like?
Old Sep 11, 2006 | 03:22 PM
deadman's Avatar
Car: 89 camaro
basically the timing is set by my friends ear but it seems smooth . funny you ask this because that was going to be another question of mine. ..... what should the timing look to be ? ill go buy a vaccum guage and timing light. also just picked up an edlebrock performer intake so now would be the time to set it up.
Old Sep 11, 2006 | 06:17 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Typical SBC initial advance is 8-12 with the vacuum advance disconnected.
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Oct 22, 2015 08:21 AM
Scorched1984
Sep 15, 2015 03:42 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
