carb help
Old Sep 11, 2006 | 07:54 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
carb help
my car diesels alittle bit after shut down of vehicle... the timing is dead on would the idle be to high on the carb? how do i adjust that if its the case?
Old Sep 11, 2006 | 07:57 PM
facelessnumber's Avatar
Car: 91 RS
Engine: L03 carbed
Transmission: 700R4, rebuilt+kit
Axle/Gears: 3.42, posi, disc
If your sure the timing is right, then the idle could be too fast/hot/lean. What's your idle speed, what kind of carb are you running, and how hot is your engine getting?
Old Sep 11, 2006 | 08:15 PM
Engine: 355
between 5 and 15 on rpm gauge, i have quadrajet,m and running temp bout 185-190.
Old Sep 11, 2006 | 08:22 PM
Car: 91 RS
Engine: L03 carbed
Well... 5 is low, 15 is high. If I turn my engine off at 15,000 RPM I'm sure it would diesel too. I don't remember exactly where the idle screw is on a Quadrajet, but it should be easy to find. Somewhere on the throttle linkage, it has a spring around it. Try loosening it some.
Old Sep 11, 2006 | 08:52 PM
Engine: 355
yeah yeah its a screw with spring around it a guy doin my timing was tightening it in he tightend it maybe 5 turns. s loosen that then?
Old Sep 11, 2006 | 09:14 PM
Car: 91 RS
Engine: L03 carbed
Oh yeah. 5 turns is probably way too much.
Old Sep 11, 2006 | 09:40 PM
Engine: 355
whats a good way to know its where its supposed to be?
Old Sep 11, 2006 | 10:41 PM
Car: 91 RS
Engine: L03 carbed
Crank it down until it idles at around 800.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
