Fuel pressure regulator
Old Oct 2, 2006 | 08:58 PM
jeff350's Avatar
I have a mallory 4309 fuel pressure regulator and i have connected a fuel line running from the regulator up to the back of the blower, but the fuel pressure is always fluctuating.So my question is can i run a fuel line from this regulator or do they reccomend that you don't.Should i just tap into the fuel line closer to the carbs.
Jeff.
Old Oct 2, 2006 | 09:01 PM
jeff350's Avatar
Sorry here's a pic
Old Oct 2, 2006 | 09:05 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
it's always going to fluctuate due to the engines demand of fuel, it won't just sit at 6psi rock steady. Mine moves from 9psi at idle to 6-7psi at wot while really stepping on the car. Now if it's bouncing while the motor is off, then I'd suspect something is wrong.
Old Oct 2, 2006 | 10:00 PM
jeff350's Avatar
Sitting at idle it is bouncing between 0-2psi and while reving it it hardly changes.do you think i might have to connect the line closer to the carbs.
Thanks.
Jeff.
Old Oct 2, 2006 | 10:12 PM
xpndbl3's Avatar
Car: 1984 Z28
i would try adjusting the nut on the top to make the pressure go up, basically loosen the nut then turn the screw with an allen until pressure reads 6-7 psi
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
