edelbrock question
Car: '86 Trans Am
Engine: stout 350
Transmission: automatic
edelbrock question
hi! I just got my edelbrock 1406 carb, and a rpm intake. I was looking at them and noticed some differences about them. So i thought i would ask. First, the choke electric hookup is different, will i have to change things to make it work? Second, will I have to change my throttle linkage in any way?
thanks!
thanks!
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No changes to the choke wiring, other than the Edelbrock choke needs a separate ground. Running a ground wire to one of the airhorn screws works fine.
Throttle linkage may need a little work. If you have a 700R4, you'll need to check the TV geometry.
86IROC112
Aug 17, 2015 02:00 PM
