What is this?????
Subscribe
Oct 23, 2006 | 06:58 PM
Ok guys what is this and where does it go. i have noticed a little gas coming out. I mean very little.
Reply 0
Oct 23, 2006 | 07:17 PM
Looks like the bowl vent line to the charcoal canister.
Reply 0
Oct 23, 2006 | 07:34 PM
do i need to run a line from it to the canister. you are talking about the black can looking thing that has one line from the talk and one to the carb
Reply 0
Oct 23, 2006 | 07:55 PM
That's the one. It prevents vapours from the float bowl from going into the atmosphere and stores them to be burned later.
Reply 0
Oct 24, 2006 | 01:03 PM
Quote: That's the one. It prevents vapours from the float bowl from going into the atmosphere and stores them to be burned later.
so what should i do than?
Reply 0
Oct 24, 2006 | 03:36 PM
Well, why is it disconnected?
Reply 0
Oct 24, 2006 | 05:55 PM
You also appear to be missing the canister control valve. If you had it, you'd know it. . .
Reply 0
Oct 24, 2006 | 09:23 PM
well its never been connected. i have know idea what to do with it. should i block it off or something or should i run a hose from it to the inlet on the canister that says "Carb"
Reply 0
Oct 24, 2006 | 09:38 PM
It can be blocked off. With that open element air cleaner you've got, emissions apparently isn't a concern for you. There's a bowl vent going underneath the air cleaner to provide the needed atmospheric pressure in the fuel bowl.
Reply 0
Oct 24, 2006 | 09:44 PM
Quote: It can be blocked off. With that open element air cleaner you've got, emissions apparently isn't a concern for you. There's a bowl vent going underneath the air cleaner to provide the needed atmospheric pressure in the fuel bowl.
so run a line from the carb to the air cleaner?
Reply 0
Oct 24, 2006 | 09:45 PM
No, just cap the fitting.
Reply 0
Oct 24, 2006 | 09:49 PM
Quote: No, just cap the fitting.
thats what i needed to know, thanks, i owe you guys a lot
Reply 0
Oct 26, 2006 | 09:47 AM
It just pulls vacuum, if its not being used just cap it off
Reply 0
Oct 26, 2006 | 11:27 AM
No, it doesn't pull vacuum.
Reply 0
Oct 27, 2006 | 01:56 PM
Doesnt it pull the fumes from the canister back into the engine to be burned ?
Reply 0
Oct 27, 2006 | 02:33 PM
No, it just vents the vapors to the vapor canister when the engine isn't running. The vapors are purged from the canister when the engine is running via the line tee'd to the PCV line.
Reply 0
Oct 28, 2006 | 10:21 AM
well i pluged it. is it normel if its not plugd for stuff to come out. kinda like dirty gas or something
Reply 0
Oct 30, 2006 | 12:33 PM
No, it's not normal. It means your fuel bowl is overfilling.
Reply 0
Subscribe
