One more thing??????
Old Oct 23, 2006 | 07:04 PM
outlawracer's Avatar
Car: 82 camaro berlinetta/87 sport coupe
Engine: 87 LG4 305
Transmission: world 5speed
Ok what do these do. The one plug on the right when plugged in she runs kinda bad. The other one on the left, I have know idea what it does
Attached Thumbnails One more thing??????-100_43979.jpg   One more thing??????-100_43988.jpg
Old Oct 23, 2006 | 07:08 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Those are the connectors for the throttle position sensor and the mixture control solenoid. They're essential parts of the CCC system.
Old Oct 23, 2006 | 07:36 PM
Engine: 87 LG4 305
witch is witch, what if the throttle position sensor isnt plged in, and same for the mixture control solenoid
Old Oct 23, 2006 | 07:53 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The first picture is the TPS, the second one is the MCS. The car won't run properly with either of them not working.
Has the computer been removed from the car?
Old Oct 23, 2006 | 08:38 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
This is in your 500HP 10 second no-cage camaro eh?
Old Oct 23, 2006 | 09:16 PM
Engine: 87 LG4 305
yes and no, i took out the 383 and the ford 9. now she just has an old lg4 and a 1992 trans am rear end.
Old Oct 23, 2006 | 09:27 PM
Engine: 87 LG4 305
no the comp is still in, but almost nothing is working. a lot of the electril has been cut before i got the car. now as of right now the MCS is pluged in. the TPS isnt pluged in but when i do plug it in the idel drops pretty hard and she doesnt run very good. tonight im going to drive to work with it pluged in and see how she runs. what do you think
Old Oct 23, 2006 | 09:59 PM
Sonix's Avatar
Car: 1982 Trans-Am
Sounds like a familiar situation.
Might as well go to a non-cc setup if the electrical is all hacked up anyway.
morrow
Jan 13, 2024 12:29 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
TheExaminer
Aug 19, 2015 10:07 PM
Bob88GTA
Aug 18, 2015 03:31 PM
