carbbed fuel pressure regulator????
Old Oct 28, 2006 | 12:12 AM
fg_stadium's Avatar
I have a 88 camaro 2.8 car that I'm putting in a carbbed 350 and need to know what psi regulator to get to retain the stock fuel pump?
Old Oct 28, 2006 | 08:17 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
I used the Mallory 3 port
Old Nov 2, 2006 | 09:40 AM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
you can use any regualtor as long as its a bypass regulator. i used the barry grant #17021 diaphragm bypass and its working great for me. thier are quite a few options out thier just make sure you are not using a deadhead style regulator. your stock pump needs a return line if you dont have one then you will burn it out within a week.
Old Nov 3, 2006 | 12:02 PM
lneal's Avatar
Anyone ever use the NOS 15851? I'm swapping out a TPI for a carbed 383 and thinking some day I would go back to FI and this one has a wide pressure range 5-50.
Old Nov 3, 2006 | 12:43 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i'd use mallory 4309 for carbs and buy a FI only regulator if you ever made that swap again.
Old Nov 6, 2006 | 01:54 PM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
That sounds like a decent idea, I would just be concerned that if 5psi is the lowest that gauge goes - and a carbed 350 opperated normally between 5-6psi, then you wouldnt be able to diagnose a fuel pressure drop under 5psi.
Old Nov 20, 2006 | 05:43 PM
gapimpin's Avatar
Engine: 383 LT1
the regulator has nothing to do with verifying a pressure drop issue thats what the fuel pressure guage between the regulator and the carb is for... wich im sure your gonna remember to install right fg....lol
Old Nov 20, 2006 | 05:50 PM
xpndbl3's Avatar
Car: 1984 Z28
a carb fuel pressure guage goes from 0-15psi in 1psi increments
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
