gas tank pickup
Old Nov 16, 2006 | 07:35 AM
Swim500in5's Avatar
Car: 83 Z-28
Engine: 305 Qjet
Transmission: 700r-4
gas tank pickup
im doing the gas tank pickup, and after reading looking at the tread im not sure about the fuel guage, what do you do with the two black wires do you need either to make the fuel meter work, is one a ground wire. for the fuel guage
Old Nov 16, 2006 | 11:52 AM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
Is your gas gauge not working? My LG4 (carb) gas tank has two wires. One grounds the sending unit and the other connects to a potentiometer (0-90ohm variable resistor). The connection is a weathertight connector directly above the rear axle. You could probe the gas tank end to measure the resistance of the sending unit. You could also insert a 90ohm resistor on the car side, then short it to simulate full and empty.
Hope this helps.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Bohemian
Aug 15, 2017 05:11 PM
TBRays98
Sep 6, 2015 05:05 PM
Strick1
Sep 6, 2015 10:38 AM
