Holley DP
Old Jan 7, 2007 | 10:54 PM
85Firebird350's Avatar
Car: 1984 Firebird T/A
Engine: 406sbc
Transmission: TH400
Axle/Gears: Moser 9"
Holley DP
I have a Holley 650 DP that I want to put on my 383 stroker, the only problem is I looked at the manual online and it says that its not compatible with overdrive trannys. I have a th700-r4 tranny with OD? Am I treally not going to be able to use this carb or is there something I can do to run it? I got the carb for free so if I can't use it no loss to me.
Old Jan 7, 2007 | 11:09 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i'd go bigger than a 650 on a 383, but regardless holley makes a bracket for 700R4 transmissions.
Old Jan 7, 2007 | 11:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
As long as you duplicate the geometry of the original throttle arm, you won't have any problems.
Old Jan 7, 2007 | 11:23 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
https://www.thirdgen.org/forums/carb...bles-carb.html
check the link, part numbers and pics of my DP/700r4 setup.
works like a charm.
Old Jan 8, 2007 | 01:15 AM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
I have a holley bracket that is designed for exactly what your trying to do. I was trying to ebay it right now. If that doesn't sell I will send you some pics if you want and maybe you would want it.
Old Jan 8, 2007 | 01:58 AM
Engine: 406sbc
Transmission: TH400
So what cables or brackets would I need? My car is a 1984 and I want to be able to run this carb instead of something else. If someone could give me part #'s it would be greatly appreciated.
Old Jan 8, 2007 | 02:35 AM
Engine: 406sbc
Transmission: TH400
How hard is it to install these two parts? I'm guessing not that hard. But now I know what that other cable is for under my hood, I actually asked a mechanic and he didnt know what it was. but now I know its a tranny cable. So with these two parts I can use my 650 DP with no problem? I also have a Holley 750 Supercharger DP, would these brackets work with that carb too?
Old Jan 8, 2007 | 02:46 AM
izcain's Avatar
Engine: 584
Holley part # 20-95 they label it as a Overdrive Trans bracket. Works like a champ for your double pumper
Old Jan 8, 2007 | 02:56 AM
Tobias05's Avatar
3 bolts install both brackets, just in case no one took the time to look at the link?
along w/ the 20-95 u need the tv valve corrector(20-121) that bolts to the throttle, like in my picture. both pieces required. 3 bolts, 10 minutes, easy.
Old Jan 8, 2007 | 03:11 AM
Engine: 406sbc
Transmission: TH400
Well i guess I have to get those two brackets. I just placed a bid on one of them on ebay(20-95) and i think I'm just going to buy the other one brand new if I cant find one somewhere.
Old Jan 8, 2007 | 03:12 AM
izcain's Avatar
Engine: 584
What was the sellers name it was probably mine that im selling on there lol
Old Jan 8, 2007 | 03:24 AM
Engine: 406sbc
Transmission: TH400
Yeah it is you, I matched the locations. I'de rather buy from a fellow member than some dealer or whatever.
Old Jan 8, 2007 | 09:28 AM
izcain's Avatar
Engine: 584
Yea I agree. At least you know where it is coming from (IE. the boards)
Old Jan 8, 2007 | 12:47 PM
Engine: 406sbc
Transmission: TH400
I'm just glad I can use my DP carbs instead of buying a new one. saves me about $450. How does these brackets let me use my OD unit on my car though?
Old Jan 8, 2007 | 07:45 PM
izcain's Avatar
Engine: 584
It has the provisions for hooking up your T.V. cable and your factory throttle cable.
Old Jan 11, 2007 | 07:30 PM
Swim500in5's Avatar
Car: 83 Z-28
Engine: 305 Qjet
Transmission: 700r-4
i have them
ive got those 2 brakets make me an offer, they were $20 each when i bought them. never used them, i can send a picture
Old Jan 17, 2007 | 08:36 PM
92Z28/RS's Avatar
Car: 92 Z28 and 92 RS
Engine: 383
Axle/Gears: 4.10
It can be done. I have a 650 on my 383 and it works good with my 700R4 tranny. I'm going to try a 750 this spring; hopefully I will improve my 1/4 times.
RaverRacerX
Mar 17, 2026 01:49 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
