Which carb spacer to have ??
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Which spacer is good for my motor ? I have a mighty demon carb and a weiand stealth intake. Right now I have a barry grant 1 inch combination spacer. But I just seen a spacer from HVH that is 1 inch made for my intake. Should I stay with what I got or switch?
Transmission: 4L80E/4L80E
Try and see is about the only way to know.
What do you use the car for? If racing, having both spacers at the track and doing back-to-back runs with what you have, the other one, and none, then back to the one you have, etc., is the best way to determine what the engine wants.
