cuting hole for fuel pump
Old Jan 25, 2007 | 11:39 AM
Duke901's Avatar
Car: 89 Formula
does anyone have pics of the hole they cut when they took there pump out from the top. thank you
Old Jan 25, 2007 | 11:58 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
First, I would strongly discourage you from doing that.
But, if you insist, search on the Engine Swap forum, especially the "Father/Son" sticky at the top. They repaired someone else's hack job.
And, no matter how well you do it, it is still a hack job, IMHO.
Old Jan 25, 2007 | 12:54 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
If you plan on pulling the pump numerous times in the future then it may make sense, but it's quicker to drop the tank once than the cut an access hole the proper way.
Old Jan 25, 2007 | 06:14 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
here`s a picture I saved a while back for just in case
Old Jan 25, 2007 | 07:12 PM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
this is OT but greeze you have a BEAUTIFUL Z28!
and back on topic...PLEASE don't do this to your car...it is a unibody structure and this really isn't good for the overall sturdiness of the chassis. not to mention it's the lazy man's way out of a simple job...
Josh
Old Jan 25, 2007 | 08:19 PM
pearl_iroc's Avatar
Car: 1988 Iroc-Z 28 Camaro
Engine: LSX
Transmission: MN12
well despite everyone who says its a hack job.......its just there opinion and its also there opinion that it weakens the structure of the car id like to seeproof that this is true, and by proof i want to see pics of a car the collapsed because of it...........the only I problem with doing this is that it is very very very dangerous wen u cut the access panel cuz if u hit the tank it will spark..........heres sum pic of the proceedure wut i did,this isnt my car but i have done it on mine the EXACT same way juss my pics were on my camera phone an are low quality but i followed this guys pics
Old Jan 25, 2007 | 08:37 PM
Josh
Thanks!! I`m glad someone likes it check that cardomain site in a few weeks, the car has had some major changes lately! I kinda agree with you along with the majority here, for a daily driver it`s not a good thing but for a "pro street" it might just be fine. I`m only guessing but I think the poster is putting together a fairly potent car
Old Jan 25, 2007 | 08:38 PM
you're welcome, it is a really pretty car that is deviously stock looking . and yes, reading the specs it sounds like the poster is gonna have a beast on his hands!
Josh
Old Jan 25, 2007 | 09:35 PM
Duke901's Avatar
Car: 89 Formula
if i did the hole how hard is it to undo the metal lines, so i can get the pump out
Old Jan 25, 2007 | 09:37 PM
its not too bad...just gotta get a pair of pliers and GENTLY turn 'em back and forth to break 'em loose then with a little force (due to the metal lines pushing against them) just slide 'em back...
good luck however you decide to do it!
Josh
Old Jan 25, 2007 | 09:40 PM
Duke901's Avatar
Car: 89 Formula
ok cool thank you also with it being a 85 does it have the 5 bolts that hold the pump in or the snap ring style
Old Jan 25, 2007 | 10:15 PM
should be the snap ring, but i'm not positive...
Josh
Old Jan 25, 2007 | 10:19 PM
Duke901's Avatar
Car: 89 Formula
ok some pics i see have the 5 bolts and some i see have the ring
Old Jan 25, 2007 | 10:21 PM
it'll be just like everything else GM...half and half...lol
Josh
Old Jan 25, 2007 | 10:25 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
JC, PLEASE DON'T DO IT, PLEASE
Old Jan 25, 2007 | 10:26 PM
Duke901's Avatar
Car: 89 Formula
lol
Old Jan 25, 2007 | 10:37 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Look at this
I am not saying anything about your abilities but PLEASE DON'T cut a hole
https://www.thirdgen.org/forums/west...ht=craigs+list
Old Jan 26, 2007 | 12:02 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Do not cut a hole. Cut an "opening"
Old Jan 26, 2007 | 08:58 AM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
In my opinion, if I saw a car with this done, or if the owner told me that he did this, I would think twice about even being seen with his again. That is probably one of the laziest things you can do. How hard is it to drop the tank? (Answer: NOT THAT HARD)
Old Jan 26, 2007 | 09:04 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
This has been debated a million times. I will cut an acess panel before I hack up my exhaust system to get my tank down. Some people have welded exhaust which makes the tank more tricky.
Old Jan 26, 2007 | 11:47 AM
pearl_iroc's Avatar
Engine: LSX
Transmission: MN12
there are so many factors u could argue for or against the access panel, but i have still never seen ne one complain of negaive effects of cutting the access panel.........
Old Jan 26, 2007 | 12:27 PM
honestly...i have had a car with an "access hacking" (i call it that because this one LITERALLY looked like someone had RIPPED it apart...), it really didn't make any difference...but i still don't like cutting into the car unless i just have to...guess it really doesn't matter though
Josh
Old Jan 26, 2007 | 02:51 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Take everything you hear here with a big truck load of salt.
I did the same
Half the sites said it was dumb and my car is gonna fall apart now causes they are so weak back there. And other half said when I installed my RSTB [rear shock tower brace] that it was also dumb because the cars are so stiff it doesn't do anything.
tips:
That how I did it also. Hacked a hole in the back and cut the lines. There is a place down farther to remove lines right but its for when ya pull the tank. So ya gotta cut the lines.
I used steel braided rubber line to put them back together. Use double clamps on both ends and crank it down. Folks have done that for years with just regular rubber on tranny lines. Mucho higher pressures.
If you use just reg rubber the sharp bends can make the hose wanna kinda kink over. Put a hose clamp or two in that spot and just tighten them down enough to make the line stay a nice circle.
in 2000 they finally put a hole back there standard in the 4th gen then cancled the line.
My fuel filter is also like that. I use the same big canaster filter but one with nippled ends. Using steel braided rubber line and double clamps on each end.
Stock flared ones twisted off.
Though like above my car has front n rear STB and the entire car has been re-welded when it was gutted. No more cheesy spot welds holding my car together.
Old Jan 26, 2007 | 09:09 PM
Duke901's Avatar
Car: 89 Formula
im not to sure what way i will do it. but thanks for all the info it kinda sucks that i have to cut the metal lines though if i do it that way.
Old Jan 28, 2007 | 10:41 PM
Jim the Nomad's Avatar
Car: 2004 GTO
Engine: 5.7
actually, I searched for this topic for that very reason... seems stupid to cut up my exhaust, when a well-executed access hole could come in handy in the future...
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
evilstuie
Jan 9, 2020 08:29 PM
mustangman65_79
Apr 14, 2017 05:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
