q jet problem
Old Apr 7, 2007 | 11:06 PM
82_t/a_305's Avatar
Car: 1982 Trans Am
Engine: 305 H.0
Transmission: th350
q jet problem
i just put another q jet on my 82 t/a , the old one was screwed and i had a rebuilt one lying around so i changed it , but now my car will idle for a minute then the rpms will drop and it will die, is it the fast idle or choke?
Old Apr 7, 2007 | 11:11 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Re: q jet problem
Sounds like maybe the choke is stuck on and causing it to load up and stall.
Keep the air cleaner off and start up the car and watch to see if the choke opens up or if it stays shut.
If the choke never opens, check to make sure you have a FULL 12v on the choke wire! If so it may be a bummed out unit.
Old Apr 8, 2007 | 09:14 PM
82_t/a_305's Avatar
Car: 1982 Trans Am
Engine: 305 H.0
Transmission: th350
Re: q jet problem
the choke stays open i gotta adjust it , but i got the car running and driving , just having choke problems
Old Apr 9, 2007 | 11:40 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: q jet problem
I know i've posted some detailed instructions on how to troubleshoot and adjust your choke.
If you want some tips try searching with my name and "choke", in the carb board. Should yield a few good threads.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
86CamaroDan
Sep 29, 2015 10:08 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
