Open Element?
Old Apr 11, 2007 | 10:39 PM
TG Goose's Avatar
Car: 1985 Camaro Z28
Engine: 355 SD TPI
Transmission: 5spd w/Hurst Short Throw
Axle/Gears: 4th Gen 3.42 LS1 Brakes
Open Element?
which of these XTREME COMPLETE ASSEMBLIES is the right one for a LG4? I dont know if its drop base, standard etc... it would be for a QJet on a 305, stock hood.
http://www.knfilters.com/universal/X-stream.htm
Old Apr 11, 2007 | 10:51 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Open Element?
The one you want for a factory air cleaner is PN 66-1201. That one is for factory Chevy/GMC air cleaners.
Looks like it would be taller than the original LG4 lid though - it looks to be the same as the taller '70s truck lids. You'll probably need to change to the taller truck filter (which is a good thing - more filter = more breathing potential). If it will fit under the hood, which it should if you have the stock intake and carb, then thats what you want.
Old Apr 11, 2007 | 11:20 PM
TG Goose's Avatar
Engine: 355 SD TPI
Re: Open Element?
I was actually looking for which one of the XTREME COMPLETE ASSEMBLIES is right for my car. sorry for the misinformation.
Old Apr 12, 2007 | 11:14 PM
Air_Adam's Avatar
Re: Open Element?
1-1/4" drop with the 3" tall filter will probably work the best. You do still have the Qjet right?
Old Apr 13, 2007 | 12:34 AM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Re: Open Element?
I had a 3"x14" without the drop base on my '86 TransAm with the stock Q-jet. No problems. 5 1/8 neck BTW. E-165066-3010 Should work fine
Old Apr 13, 2007 | 05:08 PM
TG Goose's Avatar
Engine: 355 SD TPI
Re: Open Element?
that will fit under the stock hood? This is still with the stock QJet as well. thanks for the information
Old Apr 13, 2007 | 06:53 PM
Mikz86TA's Avatar
Re: Open Element?
I had the Edelbrock signature series chrome base and top with the 14x3 K&N filter. I then switched to the K&N Xstream lid but kept the rest (base and filter) the same. I have had these on the Q-jet, Holley and BG Demon under my still stock hood. Its a TransAm so it angles down at the front more than a Camaro does. It leaves a slight impresion on the underhood liner but nothing damaging.
Old Apr 14, 2007 | 02:38 PM
ZROLimitRacing's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 5.0 305 Code H
Re: Open Element?
you just have to make sure you get a drop base, on my 14 x 3 i did have to use a 1/4 inch riser to make it fit well. just make sure that your rod sticking out of the carb isnt to long when you change the air cleaner set up or you will have a very noticable upwards dimple in your hood lol
Falcon50
Aug 22, 2020 03:26 PM
Pac J
May 17, 2020 10:44 AM
FueledSoul
Sep 29, 2015 08:58 PM
drumstixer
Sep 29, 2015 03:02 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
