fuel pressure problems
Got my car running this week and am having alot of problems. I changed the in tank pump to a walbro 255 and am running a Mallory FPR. At first i would have to change the FP what felt like every time i started it now it will not drop below 9 i can take the screw right out and it wont go below 9. The only things changed since it was running at 6.5 was it now has a 1/2 tank of gas and i changed the jets so im pretty pissed.
Transmission: 4L80E/4L80E
Make sure your return line doesn't have any restrictions, such as an adapter that's too small.
Re: fuel pressure problems
I have a elbow that comes right out of the regulator. But like i said it was fine it would hold the right pressure until i changed jets and and put more hen 1/2 tank of gas in it.
I guess I don't understand the chain of events. I was under the impression that it wouldn't keep a steady pressure after you changed the pump.
It was ok then just one day the pressure wouldnt drop below 9 psi. Today i went out a bit ago and its fine???? i dont get it im going to change the diaphram even though the regulator is new.
Ok so the surging out line stuff is gone but my pressure is still constantly changing ill set it drive for 10-15 minutes and its different. Usually it will go down i dorve for a bout a hour the other day and then it started acting funny and i opend the hood pressure was at 0 i had to adjust back to 6.Will heating of the gas say from my dual exhaust cause this constant change in pressure?
If i cant figure this out before week out im putting a pick up tube in and going to a external pump or maybe try running a new return line.
TIA
TIA
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Are you revving it up for a bit while setting the FP?
I know guys that just set the pressure and go, then have issues like this because they didnt rev it up a bit to allow the gas in the bowls to go down low enough to allow fresh gas into the bowl giving a true reading of the pressure...
Are you using the vacuum port on the reg? It is only needed for supercharger applications.
Ill give the reving and setting it a shot. Im not using the vacum booster thing. Ill let you know how it works out.
Here is a clip of my car running http://media.putfile.com/383-stroker-iroc
Well i cant wait any longer im tired of dealing with this problem im going to buy a holley blue and regulator put a pickup in the tank and figure something out for a filter. Anyone intrested in a 20 minute used Walbro 255 and a mallory fpr let me know
92camaroJoe
Aug 13, 2015 06:07 AM
