Replacing power valve/jets
Old May 28, 2007 | 06:30 PM
Demon355's Avatar
How hard is this to do? And how do you do it?
Old May 28, 2007 | 07:49 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
Re: Replacing power valve/jets
Normal Holley or DP?
But still very simple, i can evan show you pics if you want.
Old May 28, 2007 | 07:52 PM
Demon355's Avatar
Double Pumper. 650cfm.
Old May 28, 2007 | 09:16 PM
VenomX-87's Avatar
well there are 2 jets and one power valve in eatch metering block, Id say you would have 2 of them.
well all you need is 1 flathead screw driver, 2 bowl gaskets, 2 metering block gaskets, 2 powervalve gasket (looks like a big metal washer) and i don't know if the primary jets have gaskets. now what you do is remove the bowls and the main jets are on the outside face of the metering block then peal the metering block off the carb (this can be very hard if it hasent been done in ages, Mine felt like it was welded on) and the power valve is on the other side all up it took me about 25min.
when i get home ill upload some pictures, if i can find em.
Old May 29, 2007 | 02:18 PM
Demon355's Avatar
Pics would help alot, thanks!
Old May 29, 2007 | 04:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Most universal DP's only have a power valve in the primary metering block.
Here's an expanded view of the carb. Not all parts apply specifically to your carb. http://www.holley.com/data/TechServi...ded%20View.pdf
Old May 29, 2007 | 05:08 PM
VenomX-87's Avatar
Sry I couldent find the pictures last night, I think there on my GF's laptop and she had it at work with her.
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
Brcharrelson
Aug 26, 2015 07:47 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
