Carb Swap
Old Jun 12, 2007 | 05:32 PM
Brad01's Avatar
Carb Swap
Hey Guys, I recently replaced my Rochester with a Holly. Can I still use the same distributor? Mine does not have the vaccum advance. Thanks
Old Jun 12, 2007 | 05:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No, you need a distributor with vacuum and mechanical advance.
What engine? What Holley? What transmission? Why?
Old Jun 12, 2007 | 05:49 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
Re: Carb Swap
Hi there, You will need to replace the distributor to a HEI (vac advanced) one.
You will also need to find away to lock up the TTC when driving and you will need the T.V cable corector bracket/cable mounting bracket.
What Holley do you have?
EDIT: Five7kid beat me to it.
Old Jun 12, 2007 | 06:16 PM
Brad01's Avatar
Re: Carb Swap
It's a 750 Holley. Why do I have to change the distributor?
Old Jun 12, 2007 | 06:20 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Carb Swap
The stock distributor depends on the ECM to advance the timing, which in turn depends on sensors on the stock carb which aren't on your Holley.
Old Jun 12, 2007 | 06:22 PM
Brad01's Avatar
Re: Carb Swap
So the car will run like crap? What happens if I leave it the way it is
Old Jun 12, 2007 | 06:50 PM
five7kid's Avatar
You have too choices: 1) Too little advance, or 2) Too much advance.
Still haven't heard an answer to the "why" question. As in, why did you change it?
Old Jun 12, 2007 | 07:52 PM
Brad01's Avatar
Re: Carb Swap
The rochester was leaking, the holley was free. So, I will be fine running it how it is?
Old Jun 12, 2007 | 08:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Carb Swap
No, you'll either have too much timing, leading to detonation and eventual engine damage, or too little timing giving reduced performance, worse mileage, and early plug fouling.
Old Jun 12, 2007 | 08:12 PM
VenomX-87's Avatar
Re: Carb Swap
nup you need a HEI distributor or the car will run like a slug, I don't think they are very expensive and they are very easy to install.
1: Unplug/remove the old distributor (make shure you know where the rotor is pointing).
2: Insert the HEI one into the engine with the rotor at the same direction as the old one (alowing for the screw style gears). ADD: also you MUST make sure you slip the key (in the bottom of the dis shaft) into the oil pump slot or you will have big problems.
3: hook up the 4 wires (has what wire goes where on the distributor).
4: Start car and set timing to 6* advanced.
EDIT: Ok this time Apeiron beat me to it... damn im slow today.
Old Jun 12, 2007 | 08:14 PM
Brad01's Avatar
Re: Carb Swap
Ok, What about the Vaccum line? Also what year vehicle could I pull the HEI Dist out of?
Old Jun 12, 2007 | 08:26 PM
VenomX-87's Avatar
Re: Carb Swap
just run a ported vacume line from the carb (metering block) to the distributor.
What i mean by screw gears is the gear on the bottom of the distributor the gears are screw like so when you remove it the rotor will turn like 1/8th of a rotation so before you remove it note what exact direction it is pointing and when the newone is installed make shure it is in the exact same point or you will be 1 tooth out on the cam gear (you will see what I mean when you remove the stock distributor).
EDIT: :S you edited you post after i replyed......
LOL oh well.
Any GM V8 pre 1982 (I THINK).
Old Jun 12, 2007 | 08:36 PM
Brad01's Avatar
Re: Carb Swap
Ok, I think i got it. Thanks !
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
cstrobel65
Aug 15, 2015 10:19 AM
