How to replace float?
Old Jun 27, 2007 | 11:04 PM
Morder.'s Avatar
Car: 20 M550i xDrive
Engine: LB9 305 TPI
The float in my carb is bad and stays sunk, I know I have to take off the air horn, but is there some sort of adjustment that needs to be made?
If it helps I have a Carter Q-Jet and the numbers read:
17059205
2408 CBD
The carb has been rebuilt already not too long ago, but since I'm taking off the air horn, should anything else be replaced?
Old Jun 29, 2007 | 11:04 AM
Damon's Avatar
Re: How to replace float?
There is a built-in weak point in the arm of a QJet float. Adjustment to the float height is accomplished by bending the float arm at that point.
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
Irocohio
Aug 12, 2015 08:03 AM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
