600 vac or double pumper?
Car: 88 Formula, 77 T/A, 96 Z28
Engine: LO3, W72, LT1
Transmission: 700R4, 350, 4L60E
Axle/Gears: 3.42, 3.23, 3.23
I currently have the following combo; LO3 long block with L98 cam and 1.6 RR, flowtech headers, underdrive pulleys, no cat, smog, or egr, non computer HEI, 3" exh w/flowmaster 80, performer intake, 600 vacuum secondary holley, nitrous works 125hp plate, a/c deleted, 700r4 w/2000 stall, 3.42 posi 10 bolt
would I gain or lose initial acceleration by changing to a 600 double pumper
Car: 1986 Z-28
Re: 600 vac or double pumper?
Try it and see. That's off course you have access to one to try. Also, where is the timing set at? That can effect initial acceleration.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
i went from a 600vac to 650DP, didn't really notice any differences except up top.
shooters and cam swaps would probably make a bigger difference than the carb swap itself, tip in wise.
I went from a 750 VS to a 750 DP on my zz4 crate motor. Night and day difference. The car ran much better with the DP. Smoother all thru the RPM range. I even think mileage picked up a tad. I wont ever use a VS carb again for any kind of performace application.
Car: 1986 camaro z28
Engine: vortec 5.7
personally i would say a vs is more applicable in most situations than a dp, a dp is mainly used to deliver more fuel when u smack the pedal, so unless your set up can handle that u should most likely stick with the vs
skinny z
Oct 5, 2015 06:23 PM
