Carb or TPI?
Car: 1986 Irocz28/04 GMC Yukon
Engine: Ram Jet 350(*TPI*)
Transmission: Turbo 400 w/1500 stall
Carb or TPI?
Just want to ask a simple question.... Which would be better to have in you guys opinion?
1. a 600 -650 carb with a torker intake(have intake)?
2. or leave it tpi?
This is what i have: 350, with a .498'' lift comp cam, world class comp heads, roller rockers, headmann headers, borla street/strip exhaust. the motor was in another iroc of mine that ran 13.20's in a 1/4. with a 750 dp edlebrock carb, and an performer intake.
2. or leave it tpi?
Last edited by RocsRose86; Aug 27, 2007 at 10:48 PM. Reason: didnt list the intake on the motor originally!
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Carb or TPI?
Keeping the TPI would by far be the easier and cheaper solution. The only thing a Torker should be put on is a junk pile.
Re: Carb or TPI?
why in a junk pile? That torker was on my other iroc b4 i junked it with that same motor running 13.20, I thought that was pretty good. But i am just really getting into building my own motor. anyway i like the performer series also. I just want a clean set up.
I have a ram jet, tpi and an lt1 intake and plenum. I wanted to make it look stock, but have it when i want it. I got the ramjet off the motor when i bought it from summit. the lt1 is from my old vette, and the tpi is the stock manny that was originally on this car. but i dont have any of the comps, what should i get if i go that route?
Engine: 383 Carb
Transmission: 4L60
Re: Carb or TPI?
The Torker is a very old, outdated design that's surpassed in performance by pretty much any other intake, including a stock one.
Engine: 383 Carb
Transmission: 4L60
Re: Carb or TPI?
Performer RPM, or RPM air gap, or whatever Weiand's current equivalent is.
Re: Carb or TPI?
Well I wanted to put the anniversary holley 4 brrl but didnt have enough cash in hand at the time. Any other carb and intake setup suggestions? I really want her to run and scream,but be subtle at times.
Re: Carb or TPI?
Okay fellas tell me if this is ok. And which to get.
1. a edlebrock 600 cfm or a holley 600cfm for a $140 each?
2. Edlebrock performer rpm intake or a edlebrock rpg $75.00 each?
Re: Carb or TPI?
this is on a budget that is why i ask.
Engine: 383 Carb
Transmission: 4L60
Re: Carb or TPI?
I'd take the Holley over the Edelbrock, but it would maybe depend on which Holley it is.
Where are you seeing an Edelbrock "rpg"?
Car: 1987 Iroc-z Convertible
Re: Carb or TPI?
I think he meant rpm I would definitely go with the holley also otherwise just find a quadrajet for about $25 and rebuild it instead of $140 for the Edelbrock
Re: Carb or TPI?
yes rpm. the holley is a 600 anniversary quaddra-jet.
beachrodder
Aug 25, 2015 08:05 AM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
