700DP clearance problem
Old Sep 3, 2007 | 12:19 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
I have a 700DP w/ 50cc accel pump on the rear and 30cc pump on the front. I'll be bolting this to a Perf RPM Air Gap intake. My problem is the rear accel pump arm hits the intake which causes it to push on the pump about half way. I know a 1" spacer would take care of this, however I had planned on using my factory hood. Has anyone run across this problem and if so did you have any problems with clearance on the factory hood?
Old Sep 3, 2007 | 01:11 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: 700DP clearance problem
i had the same problem cured mine with a grinding stone on a dremel. i also run a 1 inch spacer for my aircleaner base it clears the hood but just barely i have some rash on the cover but no dents
Old Sep 3, 2007 | 01:32 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
This would take a lot of grinding from what I can tell. I'd rather not grind on my brand new intake or my accel pump arm. Maybe I can find a 1/2" carb spacer.
Old Sep 3, 2007 | 06:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Why are you using a 50cc accelerator pump? I'm not even using one on a 750, more engine, more cam, pumping E85.
Old Sep 3, 2007 | 07:35 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Its what came with the carburetor when I bought it. I have a 750 VS that I could swap out the accel pump if need be but I figured I would try it.
Old Sep 3, 2007 | 09:00 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
I went throught the same prob. On the DP's you cant do much about it. Instead of running a 1" spacer which requires two gaskets, i ran a 1in thick gasket. If you come up witha sol'n, let me know. Im currently trying to fab up a cowl hood, which seems to be the only solution i can think of.
Old Sep 3, 2007 | 10:52 PM
Car: 91 RS
Engine: 350 vortec
yeah it seems the classic 700DPs come with a 50cc pump on the secondarys.
but if you ask holley about it they have no idea
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
New2Chevy
Sep 28, 2015 12:35 AM
andy74
Sep 3, 2015 08:41 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
