pic of my fuel line.i think its my problem
Old Sep 23, 2007 | 10:25 AM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
here is a pic of my fuel and regulator. i think it causing the car to run out of power after 1st gear. my own opinion is it causing it to starve for gas by not letting it keep the psi up.do yall agree or have anymore input? oh yea im using the stock tpi pump in the tank
Old Sep 23, 2007 | 11:41 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: pic of my fuel line.i think its my problem
looks like a crappy regulator, what's your psi during a pull? You need to install a pressure guage to know if it's running out or not.
Old Sep 23, 2007 | 02:34 PM
intex1982's Avatar
ok install a pressure guage bad news not running 3.5 psi running 5 psi with regulator and without regulator 3.5 psi and so i jeted it and got the psi up to 7.5 but u give it gas it fall off really fast
Old Sep 23, 2007 | 04:32 PM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
thats not a bypass regulator... and you have a T in the fuel line connecting your supply line directly to your return line. im betting thats the problem you need to take out that t and install a bypass regulator in its place. right now all your fuel is going straight back to the tank.
Old Sep 23, 2007 | 07:09 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I'd have to agree with ga, u should have a bypass style fuel regulator there like a mallory 3 port or something similar.
Old Sep 23, 2007 | 07:54 PM
intex1982's Avatar
do u that think that why my times never change? no mater what i do to the car. i went from a 750 vac sec to a 750 dp and change the timing 10 deg and only both way no big change no mater what all it has is 13.4XX and the 750 vac sec back barrels was not opening but a lil bit and 750 dp open but no change in time
Old Sep 23, 2007 | 08:27 PM
gapimpin's Avatar
Engine: 383 LT1
could be causing it to run lean since your not getting enough fuel pressure...
i personally like the barry grant diafragm bypass regulator. its the one im using and keeps a constat 5 psi on my semi built 355.
Old Sep 23, 2007 | 09:15 PM
intex1982's Avatar
but dont u have tbi pump?
Old Sep 23, 2007 | 09:59 PM
gapimpin's Avatar
Engine: 383 LT1
yea i had a 91 firebird with a 305tbi... i pulled that out and put in a 355 vortec truck block with some p&p vortec heads airgap intake headers and a cam. runs good other than a bog from 4-5k but im blaming that on the carb.
Old Sep 24, 2007 | 08:40 AM
Damon's Avatar
I agree that you're all hosed up (no pun intended) with that setup. You're bypassing the fuel back through the return line BEFORE it even gets to the regulator. Get a Mallory 3-port and THEN it will work properly (or at least better than it does now).
It doesn't matter how you tune it at this point. Out of fuel is out of fuel. You're bypassing a ton of fuel back to the tank when you need it most in the carb's float bowls- at WOT. At idle and light throttle it'll work becuase you need very little volume going to the carb. But at WOT you need a lot of fuel going to the carb and your current setup is "stealing" a lot of that volume by bypassing it straight back to the tank.
Old Sep 24, 2007 | 11:23 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
did you get that regulator at advance? like everyone else is saying you need the right regulator, one with a return port.
Old Sep 26, 2007 | 02:44 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
LOL holy crap, it is dumping straight back to the return. Never seen that one before. I can't believe that has enough fuel pressure to run at all.
Old Sep 26, 2007 | 05:30 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Wish I could say the same.
A simple remedy would be to put a needle valve in the return line and shut it down until you maintain 4 psi at WOT.
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
