Air bleed question
Old Sep 24, 2007 | 05:50 PM
z28z34man's Avatar
Car: 1984 z28 camaro / 2019 accord sport
Air bleed question
Has anyone ever drilled and taped there air bleeds?
I would like to use standard 6 - 32 screw in air bleeds on my speed demon. could i drill out all the air bleeds with a #36 drill bit then tap it with a 6 - 32 plug tap and then finish with a 6 - 32 bottoming tap?
Old Sep 24, 2007 | 06:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If I'm reading this right, you want to switch from the air bleeds BG used to 6-32 thread bleeds.
Old Sep 24, 2007 | 06:37 PM
z28z34man's Avatar
Re: Air bleed question
i should have clarified i have a 750 speed demon they are not equipped with screw in air bleeds from the factory. The next stage up, the mighty demon, has screw in air bleeds.
correction standard air bleeds are 10 - 32 unf. Would i would need to drill with a #21 drill bit then fallow the same tapping procedure but with 10 - 32 unf taps
Old Sep 24, 2007 | 09:11 PM
five7kid's Avatar
They must have changed that since yours was made.
Old Sep 25, 2007 | 09:07 AM
z28z34man's Avatar
i hope this dosen't ofend you and i am not trying to in any way but the speed demon never got scrue in air bleeds.
Speed Demon
Mighty Demon
look at the bottom of each page at the demon features
again i am not trying to be mean or a net bully or something
Old Sep 25, 2007 | 09:53 AM
five7kid's Avatar
http://www.barrygrant.com/fromBarryG...n%20Manual.pdf Page 9.
Anyway, you can drill, tap & screw to your heart's content. I didn't find the CHP mag article about it, but the concept applies to any carb type as long as there is sufficient meat to hold them. And, that shouldn't be a problem with the BG carbs.
Old Sep 26, 2007 | 09:29 AM
z28z34man's Avatar
dose anyone know how far to drill down if i should bottom tap the hole and if there is a particular spot that you are have to start the tap at
backtothe80s
Sep 5, 2015 12:39 AM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
