Hey! MORE PROBLEMS!!
Old Oct 5, 2007 | 04:15 PM
Morder.'s Avatar
Car: 20 M550i xDrive
Engine: LB9 305 TPI
Well pictures worth a 1000 words so I took some...
Old carb:
New carb:
I think the pictures explain themself, but obviously I'm having problems with my throttle plate and throttle bracket. Is there something I need to buy? I've gotten used to dumping money in the car so I'm willing to toss more in, lol
Old Oct 5, 2007 | 05:22 PM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
Re: Hey! MORE PROBLEMS!!
you need a throttle valve geometry corrector for an edelbrock carb.... most speed shops will have them if not you can get them online for about 35bux.
Old Oct 5, 2007 | 06:59 PM
Morder.'s Avatar
Engine: LB9 305 TPI
I dont suppose I can get a link to that on summit or jegs or something?
Old Oct 5, 2007 | 07:14 PM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
You can get the geometry corrector and a new cable bracket thru summit. If you put the part number of your carb in there should be a suggested parts menu and youll find them in there..
Old Oct 6, 2007 | 10:27 AM
gapimpin's Avatar
Engine: 383 LT1
http://cgi.ebay.com/ebaymotors/TV-CA...QQcmdZViewItem
summit part number SUM-700203
Old Oct 6, 2007 | 02:21 PM
Morder.'s Avatar
Engine: LB9 305 TPI
Do I need just that or the cable bracket too?
Old Oct 6, 2007 | 08:01 PM
gapimpin's Avatar
Engine: 383 LT1
if your still using the stock intake then your bracket should be fine... if you changed to a highrise intake or something like that then yea you will need the bracket.
Old Oct 7, 2007 | 10:18 PM
Morder.'s Avatar
Engine: LB9 305 TPI
I have an edelbrock performer intake. Do I need the bracket? If possible...could I get a link to that too? lol thanks
Old Oct 8, 2007 | 11:30 AM
gapimpin's Avatar
Engine: 383 LT1
sorry dont have part numbers or links for the bracket.... i had to use 2 diffrent ones. they have a chrome one made by spectur at autozone for like 10bux. i used that for my throttle cable. then i had to get a fully adjustable one from a speedshop that bolted to my back intake bolts.
Ghettobird52
Jul 5, 2024 11:18 PM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
Ghettobird52
Apr 21, 2020 08:44 PM
Infested
May 22, 2018 11:56 PM
1992Vortec
Aug 31, 2015 08:05 PM
