Which method do you use?
Old Oct 17, 2007 | 10:51 PM
mq1kael's Avatar
Car: 2004 Chevy 1500, 86 bird
Engine: 5.3, 69 327
Transmission: auto, th350
I'm curious to know what kind of meter/method that people use to get their A/F mix correct. I'm kinda new to the bigger motor scene, even though I've put together a bunch of smaller ones. Do most of you just read the plugs or do ya buy the o2 sensor and meter? I'm going totally old school and just woul dlike to know everybody's opinion on the different ways and the pros and cons of each...
Kael
Old Oct 17, 2007 | 10:55 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Which method do you use?
Most people use a vacuum gauge for the idle mixture. Plug reading and timed acceleration is the traditional way to read the WOT mixture, but wideband O2 sensors are getting more popular.
Old Oct 17, 2007 | 11:34 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i don't bother with anything but a wideband, new fuel requirements for emissions screws up the coloring on plugs. I can fully tune a carb from idle to cruise to WOT in such a shorter amount of time with a wideband, and max HP runs at the track for slight wot tuning that anything else is just pissing in the wind for how cheap a wideband setup is these days. Those cheap $50 a/f guages that use a standard 02 sensor are not accurate for what you're trying to do as they won't give scientific numbers.
Old Oct 18, 2007 | 09:03 AM
mq1kael's Avatar
Engine: 5.3, 69 327
I don't go to the track, but I do want the best running car I can make. What's a good company/brand for the wideband setup?
Old Oct 18, 2007 | 12:20 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I think Innovate Motorsports is about the cheapest right now, apart from the Summit-branded version.
Old Oct 18, 2007 | 01:01 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Innovate LM-1 was $180 I think.
I just purchased the summit kit for $240, comes with a nice little analog gauge as well.
Elephantismo
Feb 13, 2019 12:51 AM
RS Reaper
Oct 17, 2018 07:52 PM
RedLeader289
Sep 23, 2015 06:50 AM
64Chief
Sep 12, 2015 08:05 AM
dimented24x7
Sep 6, 2015 03:51 PM
