91 Camaro throttle cable
Old Oct 21, 2007 | 01:44 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
I finally got to drive my car today after the engine swap. It felt weak and would stumble when I floored it. I started looking at the carb and found that it would only open the front barrels half way and nothing on the secondaries because there wasn't enough travel on the throttle cable. I have a Bowtie Overdrives TV cable bracket along with an optional throttle cable bracket. Has anyone ever used this brand of bracket?
Old Oct 22, 2007 | 11:13 PM
pondriver's Avatar
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
Re: 91 Camaro throttle cable
I have the same set up. I had to cut the plastic tube off the throttle cable so it had more travel. I also made a bracket that extends where the throttle cable attaches to the bto bracket. Make sense? I can get a picture if you need it.
Old Oct 23, 2007 | 08:54 AM
Damon's Avatar
Cheap-o Spectre chrome throttle cable bracket (adjustable) worked fine on my 92 when I swapped over to a carb (Holley). No modification of the throttle cable, gas pedal height was identical to stock.
Old Oct 23, 2007 | 09:35 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Yeah I would like to see what your bracket looks like. I bought some 1/8" steel and cut a 2.5"x2.25" piece off and drilled holes to move the throttle cable bracket back about 2" or so. I think this might have fixed the problem but I'll have to test it tomorrow to see if I have plenty of travel. I didn't cut the black plastic tube off yet but it'll be my next step.
Old Oct 23, 2007 | 10:15 PM
pondriver's Avatar
Engine: 350 HSR
Yep, did the same thing. I thought I could remove the tube and make it work without the plate, but it seems to work better with more travel. So, I did both.
Old Oct 24, 2007 | 11:36 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
If you could, post that picture up. Im having a similar issue and would like a reference.
Old Nov 3, 2007 | 11:12 PM
pondriver's Avatar
Engine: 350 HSR
finally took a picture.
Old Nov 20, 2007 | 11:01 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
That's exactly how I did mine.
Old Nov 21, 2007 | 06:05 AM
Damon's Avatar
Pondriver- the reason you had to cut the plastic back to get more travel is becuase you have your throttle cable stud in the wrong hole on the throttle arm.
Old Nov 21, 2007 | 08:15 AM
pondriver's Avatar
Engine: 350 HSR
Should I be in this one?
File Type: doc
Old Nov 21, 2007 | 09:28 PM
Damon's Avatar
Like this.....
That throttle cable stud is Edlebrock part number 8009 although Holley makes an equivalent one as well (don't know the part number off the top of my head). It's for Chevy throttle cables from 77-up (ring on the end of cable). It fits the hole in the throttle arm perfectly without any washers/adapters.
Because it is closer to the fulcrum point of the throttle arm it takes less cable travel to go from idle to WOT. This location works well for most mid-70s-up Chevy applications.
The hole you have marked in the document you posted is typically used for very old 1960s/early-1970s-era applications that use a metal bar from a bell-crank on the firewall instead of a cable.
Old Nov 21, 2007 | 11:21 PM
pondriver's Avatar
Engine: 350 HSR
Thanks, I'll give it a try. I guess that could also affect the TV cable too?
Old Nov 23, 2007 | 06:21 PM
Damon's Avatar
The TV cable is separate from the throttle cable so changing the stud location for the throttle cable won't affect the TV cable. Looks like you already have the right adapter on there for a TV cable.
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
timonator
Aug 13, 2015 11:27 PM
fonzie85
Aug 13, 2015 11:50 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
