How do I Adjust from not running too rich
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
I have a 4 brrl Holly carb I believe, I was told there is 2? switches where u can adjust from running to rich, I'm trying to adjust to pass emissions, please advise, Thanks
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: How do I Adjust from not running too rich
When are you running rich, at idle or at cruise?
Engine: V8 350 ci
Im running too rich at idle, Im not sure how to adjust, I need help for I can pass these stupid emissions
Engine: 383 Carb
Transmission: 4L60
The idle mixture screws on the base of the carb will set the idle mixture. Don't just blindly start twisting them to try to lean it out. Get a vacuum gauge and do it properly.
Transmission: 4L80E/4L80E
