surging
Old Dec 1, 2007 | 10:34 PM
iroc3o5's Avatar
surging
i think i have a carb problem with my computer controlled quadrajet on my 86 camaro. no engine mods. but when i stomp on it say from a stop sign, or when i reach high rpm if i have it floored, the car struggles and surges. i know i am running rich, could i be flooding it? it feels like it is not getting gas, or maybe it is getting much too much and not reacting like it should. never had this problem before. when i say it struggles and surges, it like for split seconds on and off will seem like its about to stall. can anyone put some light on this subject for me?
Old Dec 1, 2007 | 10:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Very typical of q-jets.
The secondary air valve (AV) is opening too soon. The opening is controlled by two things: The vacuum dropping at WOT releasing the choke pull-off; and the adjustment of the air valve tension spring. The sticky in the top section of this forum on the E4ME instructions tells you how to adjust the AV tension. The choke pull-off is two screws and a vacuum hose to replace.
Old Dec 2, 2007 | 08:23 AM
iroc3o5's Avatar
Re: surging
i'll check them out thanks
92camaro350cci
Oct 14, 2015 09:29 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
banksGTA
Sep 13, 2015 11:56 AM
bamaboy0323
Sep 3, 2015 06:07 AM
jbd1969
Aug 17, 2015 07:06 PM
