what to do with my 305
Old Dec 4, 2007 | 07:47 PM
bigal's1991's Avatar
Car: 1991 camaro RS
Engine: currently swapping 5.3
Transmission: 4l60e
Axle/Gears: soon to be 4:11
is it worth tryin to take my 305 and get it bored and rebuild it myself and put a better cam, heads, intake, headers and a carb .... or should i just get a 350... i would rather rebuild my 305 and make it badass.. b/c i have a very limited budget..
Old Dec 4, 2007 | 07:51 PM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
Re: what to do with my 305
the 350 would be better you can pick up a block for next to nothing at the bone yard
Old Dec 5, 2007 | 01:36 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I've been saying this for years, and I stand by it:
"For a given amount of money, you can make a 305 faster than you can by putting in a 350."
Up to a point. . .
Well, a couple of points, actually. One cross-over point is when you spend a dime rebuilding the shortblock (pistons, rings, bearings, crank, rods - any of those). Once you're to that point, go find a 350 shortblock and rebuild it.
The other point is when you make a potent engine that won't hold together with a stock shortblock - i.e., when you have to spin it so hard that rod bolts get stressed, things like that. See "rebuilding the shortblock" above.
So, go ahead and build your 305, just don't do anything that won't transfer over to a 350, or anything that requires money spent on the shortblock.
There is a thread in the FAQ forum about differences between 305's and performance improvements. Check that out for what to do to get the most out of your 305 within the bounds of the paragraphs above.
pjsparts
Oct 29, 2025 06:39 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
