back fires when coasting in 3rd but not drive until 55+
Old Jan 5, 2008 | 06:13 AM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
yesterday was driving in 3rd -- it b(ar)fed decelerating at 30 mph or faster
put it into drive and b(ar)fing quit -- never b(ar)fs until decelerating ~55
good sparks, cap, rotor, wires, right engine operating temp, 0TDC timing, no known vacuum leaks, good choke, >1 yr old o2 sensor
any ideas in what makes difference between 3rd & drive deceleration?
Old Jan 5, 2008 | 12:30 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: back fires when coasting in 3rd but not drive until 55+
you mean the popping coming out of the exhaust during decel? If so that is normal and all free flowing exhausts do this. Higher rpms in 3rd than 4th would be why it would do it at a lower mph. Totally normal though.
Old Jan 5, 2008 | 07:12 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Thanks that's one off the whatisit? list
Old Jan 6, 2008 | 04:56 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
THe difference between accelerating and letting off in 3rd and drive, is that in drive, the engine nearly freewheels when you let off the gas, because you are in OD. In 3rd, you will have engine braking, making the car pop more through the exhaust as it winds down w/ an overrich exhaust condition for a brief second.
1992rs/ss
Jan 31, 2025 05:10 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
justin57
Aug 20, 2015 07:05 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
