yay another tpi to carb (fuel pump)
Car: 88 formula
Engine: 350 goin carb
im searching all the stickys and notes as you read this, i have learned that i am way more mechanicly inclined than cpu., so ive decided to switch to a carb system. I was wondering something though, i have not seen (yet) anyone mention putting a manual fuel pump on, can i do this? reason being is that i have about 10 of them laying around and i have a budjet. that wuold also eliminate the beed for a regulator wouldnt it?
Car,
1988 t/a 350 cammed currently tpi
auto 700r4
Car,
auto 700r4
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: yay another tpi to carb (fuel pump)
mallory 4309 is $85? sell some of those mechanical pumps...OR drop the tank, remove the intank pump, fab up your own similar design carb pickup tube and then hook up the mechanical pump. For how long it takes to drop the tank, I'd rather just spend the money and get something that won't vapor lock.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You can put a mechanical pump on and feed it with the in-tank electric, as long as it's a stock-type mechanical pump with a return. This is the setup GM used to fix vapour lock problems, first as a dealer-installed repair and later as a factory setup.
Car: 88 formula
so pretty much for convienince, i should just go ahead and get the malory, are there any posts on peole doing this, that may help me.. just say yes and ill do the searching thanks
Car: 1984 Z28
several, some by me i'm sure
Car: 88 formula
o yeah ive read about 5 so far, it seems that people can quite get the presure down to 3 psi this way, say i keep my stock pump, add the mallory, is there a carb out there that can handle 7-13 psi that you know of?
an last question on the carb side, what would be best to look at from a tpi point of view with auto tranny? i think holley makes a 700ry bracket to utilize my kickdown but not cruise correct?
thanks
thanks
Car: 92 camaro
Engine: stroker
Transmission: Megaraptor
ive got 750 demon, that i set up that way (w/ the mallory return style regulator) its currently at 6 psi, why would u wanna go up to 13 psi???
Car: 1984 Z28
yea you can get the mallory down to 5-7psi no problem. As for the carb brackets, holley makes them but your cruise is gone.
Engine: 383 Carb
Transmission: 4L60
Car: 88 formula
thanks for replys, i wouldnt want that much psi, just wondering if i couldnt get the fuel low enough if there was a carb that operated around there.
looking at my suply of pumps, i dont belive i have anything that will work. my box labeled sbc fuel pump is really dodge fuel pump. o well.
one last question. (for right now any way) i saw it asked a few times but not answered, where is the easiest place to put the regulator, do i have a stock one that just swaps out somewhere in the mix or will i need to cut lines and add hoses?
Engine: 383 Carb
Transmission: 4L60
You'll need to so some plumbing however you do it. The regulator should go as close to the carb as possible, and somewhere relatively cool (eg. not mounted to the exhaust manifold).
Car: 88 formula
yeah my engine bay is neat new and clean. it would be going somewhere easy to use and not an eyesore. so i dont jam up threads id like to start a new topic in this one,
"what i have and where to go"
Currently i am running a roller 350 TPI with stock heads opened to the typical 2.02 /1.60 and `1.5 crane roller rockers. camwise i run a compcams .474 lift .....230 234 duration 111 lsa 700r4 trans with 2400 stall
what i want.
what carbs shold i be looking for? i have a holey 650 on my 84 truck and love it so id like holey.
intake.. i have no clue what intake would match up to centerbolt (083) heads, any ideas
distributor. all i know is i need a vaccume advance , do i need hei still? throw me some ideas for a roller cam if posible.
we covered the fuel
Transmission,. i know i will be loosing lockup, witch will cause a lot of heat, will i need to add the jumper in termanals or do you think that a trans coller will help keep temps down?
computer--- ill be leaving it in for spedo and such, engine wise all il be loosing is fan temp controll right? (i have no somg or a/c) also, woulnt i loose controll to my fuel pump wich brings up back to post 1
did i forget anything??
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
