400 horse fuel requirement?
Car: 91 formula ws6
Engine: 1 peice roller scat 383 4 BOLT!!
Transmission: 5 speed
hey, you guessed it, i have an over 400 horse 383 and its about to go in the car, I have no clue what i should do for fuel system.
here are my attack stategies.
1. I buy a proffesional product 30 doller regulator bypass style for efi to carb swaps
2. i get the holley blu pump and regulator kit for like 100 bucks
3. i go nuts with the braided fuel line, and full aeromotive stuff for like 1000, and do god knows what with the tank.
what is a legit, safe, track legal fuel system that wont break the bank.
and while im at it,, whats the safest way to wire the stock pump if i use it for carb?
ps- p.p intakes looked really good at first glance,,, till i mounted the carb and seen the barrells were shifted a half inch over!!
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 400 horse fuel requirement?
A bypass regulator with braided hoses would be the simplest and cheapest. You can use the existing fuel pump wiring through the oil pressure switch, adding a wire to power the pump while cranking if you like.
Car: 91 formula ws6
i was planing on going mechanical oil pressure,, cuz im not to sure what wire is what coming out of driver side,, kinda just wanna cut em... but that electrical,, i still have a month to do that... anyways
would you recomend a brand or kit, earls, russell?
thanks in advance.
thanks in advance.
Engine: 383 Carb
Transmission: 4L60
Aeroquip before Earl's, Earl's before Russell.
You can still use a mechanical oil pressure gauge, just leave the oil pressure sending unit/switch in place.
Car: 91 formula ws6
old one broke when i pulled out motor. should i just get another one, i like the idea of when engine is on fuel is on and vise versa tho
57kid- this was my cheap idea http://cgi.ebay.ca/ws/eBayISAPI.dll?...MEWA:IT&ih=008 and keep stock everything else.
im decideing upon braided line,, or even special hydrolic hose, being that i work at a parts store
Engine: 383 Carb
Transmission: 4L60
Another pressure switch would be a good idea. It wouldn't have to be integrated with the gauge sender if you're going to use a mechanical gauge.
Seems like that regulator would do the trick. It's half the price of the popular alternatives.
Car: 86 Iroc 383 carb, 97 T/A WS6
I run the professional products regulator, its a really nice piece. That company has come a long way with there quality. That thing is more than $30, its more like $60. The ebay link is the procomp regulator, I wouldnt go with it, get the PP one cause if you have any problems they will make it right.
Seth
Seth
Seth
Seth
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
If you go with it, let us know how it works out.
Car: 91 formula ws6
thank all of ya'll
this is my first full fuel sytem job. I did a search for this for days,, and can't find anything. Im going to document and photo this whole job, and if it turns out good ill post it all up for all the newbs like me.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
just search for mallory 4309, i've commented in several posts on how to do it including part numbers. VERY easy and VERY reliable.
Car: 91 formula ws6
so, just keep stock everything and put a regulator in, and some nice braided from reg to fuel log.
i dont think i have charcoal can or line.
Engine: LS1/LQ4
Not necessarily. Door #2 isn't a bad option, either. You'll have to drop the tank to remove the stock pump, though.
Big unknown is the condition of the stock pump. It may be okay now, but in a year or two might not continue to support the need. In that case, the popular Walbro 255 w/4309 is another option.
ambainb
04-25-2016 09:21 PM
