fuel preasure regulator
Old Mar 6, 2008 | 09:23 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I have a stock fuel pump on my 350 w/1406 edelbrock
it calls for 6psi max
will the stock pump put out more preasure than that and do I need a regulator
thanks
Old Mar 6, 2008 | 10:25 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
A stock in-tank electric pump will put out a whole bunch more pressure than 6 psi.
You need a regulator made with a return. The Mallory 4309 is a typical and popular choice. The $20 regulators will not work for what you need - the electric pump needs to continuously flow fuel through it to keep it cool, and the cheap regulators just stop the flow. Dead heading the in-tank electric pump will burn it out.
Old Mar 6, 2008 | 09:35 PM
jamon8's Avatar
Engine: 350 tpi
Re: fuel preasure regulator
sorry this is on a mechanical fuel pump motor
the pump is stock
do you think I need a fuel preasure regulator to keep it under 6psi
Old Mar 6, 2008 | 10:14 PM
five7kid's Avatar
Specifics are nice.
No, you don't need a regulator with an engine-mounted mechanical pump, but you do need to drop the fuel tank and remove the stock in-tank electric pump.
MustangBeater20
Oct 29, 2022 09:20 PM
deracer
Apr 11, 2016 12:04 AM
g.l.mos
Aug 22, 2015 12:02 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
