Cant decide on electric pump or mechanical one
Okay. Im going to be converting my 305 to carbureted for the time being til I rebuild a 350 and I cant decide on what to do with the fuel system. Ive still got the stock pump in the tank. I hear its advisable to not just add a regulator with the stock pump. Is that true?
If I get a mechanical pump do I need to add a regulator?
Im trying to do this as cheap as possible. I guess Id be looking at mechanical fuel pump then?
Transmission: 4L80E/4L80E
It's not true. Many, many members have done the regulator w/stock in-tank pump. You do need to use a return-style regulator, such as the Mallory 4309. It's a bit pricey, but if you use the standard $20 regulators, they dead-head the pump and that is not advisable, because the stock in-tank pump needs constant flow to keep it cool or it'll burn out.
If you use a standard mechanical pump you don't need a regulator, but you will need to remove the in-tank pump. I still haven't heard of anyone trying it, but if you use a 3rd gen style mechanical pump along with the in-tank pump, the 3rd gen mechanical pump has a return on it, so you shouldn't need a regulator.
If you don't keep the in-tank operating, it should be removed. There's a sticky in the top section of this forum that shows how to convert your pick-up to a standard style.
Re: Cant decide on electric pump or mechanical one
I was looking at the Edelbrock 1711 pump. Does this have a return on it if I take the in-tank pump out?
Could I just get a pick-up from an earlier 3rd gen at the junkyard and will it work without modifications?
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i'd just run the stock pump and put on the 4309, no reason to mess with the easiest option. Pulling a tank, pulling a pump, running new pickups, and buying a mechanical pump ALL instead of just putting on the return regulator seems like a lot of work to save maybe $20.
Car: 1984 Z28
no it works for both the tpi pumps and the tbi pumps. Set it and forget it. Use a quality pressure guage and then leave it be.
That 1711 pump costs more than the 4309 reg!
And, no, it doesn't have a return.
You can use a junkyard pickup, if you can find one.
But you can get used 1711's for like $20
I think Ill just go the route of a 4309 though. Maybe I can get a good deal on a used one
theshackle
Mar 5, 2017 06:37 PM
[For Sale] 1 3/4 budget LS swap headers NEW (CA)
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
