Engine dies in gear unless completely warm
Old Mar 19, 2008 | 06:04 AM
ekoller's Avatar
I have a 650 speed demon that has been tuned on a dyno then I took it over to another shop because the idle was surging and stalling if not warmed up ,they got everything working except I have to warm my car up to 180 degrees or it will just die if I try to put it in gear. I have checked the choke and it turns off when it should. Right now the initial timing is at 10 ( it's low I know) but the shop said it runs great and if I want more power I can take it higher. the car starts fine it that means anything.
FYI. If I let the car completely warm up it runs fine.
Old Mar 19, 2008 | 09:20 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sounds like you need to choke to stay on longer. I'm not completely familiar with Demons, but I assume you can move the choke thermostat to "richer" or "leaner". Richer just means the thermostat tension is greater, meaning the thermostat needs to warm up more to completely release.
Terrell351
Jun 13, 2021 01:13 PM
jklein337
Sep 19, 2018 06:23 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
