TBI to a Carb on a 1990
Old Mar 20, 2008 | 06:03 AM
lost_king_88's Avatar
Ok i have a 1990 Camaro RS with the 305 in it, and i want to swap the TBI to a Carb. i have a 4 barrel carb and 4 barrel intake for it. is there anything else i would need for the swap? and what would i need to do to perform the swap?
and if this question has been asked before sorry i prolly didnt see it so if you can just put a link and ill go check it out.
thanks
Old Mar 20, 2008 | 11:10 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
The first thing is to read this https://www.thirdgen.org/forums/carb...rd-please.html . The first link in that sticky is a tech article on doing your swap.
I'd sure want to know what 4 bbl carb and want intake you have before giving my blessing. Also wouldn't hurt to know why you want to do this.
Old Mar 21, 2008 | 01:13 AM
Re: TBI to a Carb on a 1990
because the TBI that i have has been torn apart by a previous owner.
I don't know the specifics on the 4 bbl carb and what intake im getting but i can check later. (still talking to the guy i'm buying the parts from)
I just want to make sure that I'm getting the right parts and that what i'm looking to do is even feasible.
Thanks for any and all Feedback.
Old Mar 21, 2008 | 05:17 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
It's pretty involved.
I did a write up on it for my myspace blog, actually... But it's relatively thorough, should give you an idea of what you're in for. I lightly touch base on as many different things as I could think of. What parts you need, what you need to do, how you need to do it, how to wire things, etc.
The frustrating part will be separating the ECM wires from the rest of hte wires and reusing the ones you need to keep, such as the one to the fuel pump relay and so on. Thats just a job of tracing wires and figuring out where they go, and whether you still need them. But after you get done you can throw the ECM in the trash and not worry about it anymore.
http://blog.myspace.com/index.cfm?fu...7C620899338328
Old Mar 21, 2008 | 07:22 AM
battyice's Avatar
Car: 1985 Z28
Engine: 355 topped with Dart heads
Axle/Gears: Stock axle with 3.73's
You can find complete TPI systems on ebay or at your local salvage yard for a reasonable cost. In the end it should be much less work to fix the system you have rather than convert to a carb.
Old Mar 21, 2008 | 02:49 PM
five7kid's Avatar
He has TBI now.
Old Mar 21, 2008 | 03:32 PM
battyice's Avatar
Car: 1985 Z28
I was under the impression it was disassembled and/or missing components and he thought it was less involved to convert to carb rather than fix the TBI system. My point is that parts are cheap and there is plenty of information available to fix whatever issues the current TBI system may have.
Old Mar 21, 2008 | 03:56 PM
im still looking for parts for a TBI, but for right the only thing i found was the four bbl carb but im still waiting on a response form the guy who is selling it
Old Mar 22, 2008 | 12:52 AM
Car: 1992 Camaro RS
What parts do you need? I just pulled my L03 out, I've got a lot of TBI parts laying around...
Old Mar 22, 2008 | 01:47 AM
pretty much i just need a new TBI, cuz the one i have is only good for a paper weight
Old Mar 22, 2008 | 04:42 AM
Car: 1992 Camaro RS
If you just need a TBI unit I've got one if you want it. Worked fine when it came off the car a month or so ago.
Old Mar 22, 2008 | 09:30 AM
well if you could email(lost_king_88@yahoo.com) me a pic of it let me know how much you want for it unless you just want to give it to me
Old Mar 22, 2008 | 02:24 PM
Car: 1992 Camaro RS
I sent you a private message.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
andy74
Sep 3, 2015 08:41 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
tero
Aug 15, 2015 02:47 PM
tero
Aug 6, 2015 06:34 PM
