carb intake question
Old Mar 24, 2008 | 05:20 PM
davep_96's Avatar
Car: 1987 Trans Am GTA
Engine: 355
Transmission: TH-700r4
i am swapping my 87 4bbl 305(Trans am) for a 89 TBI 350(from a truck). However, i was told that since i am adding a new cam and headers that i should ditch the TBI and get a carb. Will the intake from the 305 motor work on the 350? Im trying to save myself some money and since i already have the manifold i was hoping it would work. Also, should i even do a carb or should i just keep the TBI?
Old Mar 24, 2008 | 06:05 PM
bradley92rs's Avatar
Car: 1992 rs
Engine: 350 carb
Transmission: t-56
Axle/Gears: working on a 9"
Re: carb intake question
Hey welcome this is my first post but been lurking for about a year here. Just a few questions 87 so it's stock lg4 305 cc q-jet? and the truck motor is a lo5 350 tbi?
Old Mar 24, 2008 | 06:16 PM
davep_96's Avatar
Engine: 355
yeah the stock motor was a qjet 305. the new motor is a TBI 350 from an 89 pickup truck. just wondering if i could use the 305's manifold so i dont have to buy a new one. i want to make the 350 a carbed motor.
Old Mar 24, 2008 | 06:34 PM
Car: 1992 rs
Engine: 350 carb
Transmission: t-56
Should be a direct bolt on. The lo5 heads are a big restriction as is the stock lg4 exhaust imo those should be first 2 mods if you plan on any, don't make the mistake my brother did and cam and springs on stock swirlpot heads lol. Anyway do a search on here 305 to 350 swap and check the tech articals on the home page great info. off the top my head think just a 350 knock sen. is all thats needed since ccc is open loop
edit: good rule of thumb give it a day or 2 for response a lot of great info here in these guys and be specific in questions
Old Mar 24, 2008 | 06:37 PM
davep_96's Avatar
Engine: 355
cool thanks. so where can i get some better heads for kinda cheap(im on a budget)
Old Mar 24, 2008 | 06:57 PM
Car: 1992 rs
Engine: 350 carb
Transmission: t-56
I really don't wan't to give mod advice as everyone has there own goals and such. I would give it a day or 2 let some others comment and do some research on here. I used a l98 long block and non cc setup just ported a set of vett alum heads i got a killer deal on. but remem dont build a killer motor on a stock t-5/700r4 10-bolt drivetrain first freak hookup could be bad but thats whole diffrent subject hope this helped alittle just my
a good moto i have seen since i was a kid is build a car from the ground up not motor back
Old Mar 25, 2008 | 09:25 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Your 305 heads are better heads.
Old Mar 25, 2008 | 08:18 PM
davep_96's Avatar
Engine: 355
Better than the 350 heads? Would they work on the 350?
Or would it be better if i got some 350 heads off a camaro/firebird engine from ebay/junkyard?
Old Mar 25, 2008 | 09:57 PM
five7kid's Avatar
Yes, yes, and probably not.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
