What wiring don't I need after TBI to carb swap?
Old Mar 27, 2008 | 10:45 AM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
I've searched on this and couldn't really find what I was looking for. Now that I've had my car up and running breaking in my clutch, I want to clean up the engine bay and under the dash a bit. I still have my ecu hanging under the dash with all the wiring harnesses still connected. I'm pretty sure I don't need any of it. I re-wired my fuel pump to come on when I turn the key. How do I go about tracing the wiring and eliminating what I don't need? I have sooo many wires everywhere and I don't know what to do with them. I have a big loom on the pass. side and a big loom on the drivers side into the fenders.
Any help is appreciated
Old Mar 27, 2008 | 07:30 PM
89Creeper's Avatar
Car: 89 Camaro RS
Axle/Gears: Stock
Re: What wiring don't I need after TBI to carb swap?
what I did with mine was, if it wasnt hooked up with anything I cut it back to the firewall. I didn't go under the dash because im still running my lights and stuff the stock wireing and i didnt want to chance messing anything up.
Old Mar 27, 2008 | 11:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You don't have to cut anything. The ECM harness that connects to the kick panel bulkhead connector goes to the passenger side fender well. Take the plastic fender liner loose at the back of the fender well and you'll see the harness and connector. Anything that passes into the engine compartment can be taken out with the component attached to it.
Old Mar 28, 2008 | 07:58 AM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
You have to do some cutting, I had a few wires that were connected to the ECM that also ran into the drivers compartment. There weren't many but I do recall having to make a few cuts just to get the ECM harness out of the car.
Old Mar 28, 2008 | 11:46 AM
five7kid's Avatar
Are you sure they just weren't bundled together, and pulling the wires out of the bundle would have prevented the need for cutting?
Old Mar 28, 2008 | 12:59 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Yep I recall a few wires that were factory spliced into wires that ran to underneath the dash. I want to say at least one of them went to the AC compresser. I'll look tonight or this weekend and see where all they go. There weren't many but after a few hours of sorting the wires I can to cut a few to get the ECM harness out completely.
Old Mar 28, 2008 | 05:04 PM
five7kid's Avatar
AC connection through the ECM for the radiator fan is one possibility.
But, the ones I've done (admittedly not EFI), separated cleanly. Didn't even have to unbundle the harness.
Old Mar 28, 2008 | 08:40 PM
pondriver's Avatar
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
I've slept since then but I did have to solder some wires, and cut some others where they where crimp spliced. I took the entire harness out from the drivers fire wall to the ecm. I had a good shop manual and started cutting. I stretched out each end of the harness off the ground and started pulling out what I didn't need. For me the manual was a must.
MustangBeater20
Oct 29, 2022 09:20 PM
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
