carb spacer adjustments?
Subscribe
Apr 8, 2008 | 07:49 AM
I am going to be putting an open 3/4" carb spacer on a 350 with edelbrock intake manifold and edelbrock 650 carb. do i need to make any adjustments to the carb when do this?
Reply 0
Apr 8, 2008 | 09:06 AM
You'll know when you fire it up. It may be fine, it may need some tweaking.
Which manifold do you have? What cam, exhaust are you running?
Reply 0
Apr 8, 2008 | 11:53 AM
Re: carb spacer adjustments?
its the performer dual plane... voodoo cam .468/.489 its on summit (60102lk). hooker headers, single in dual out flowmaster. what would need tweaking? just those two screws in the front of it? thanks.
Reply 0
Apr 8, 2008 | 01:39 PM
Maybe idle mixture, rods, jets, or step up springs.
The spacer can change the "signal" various carb calibration items see.
In case you haven't seen this:
http://www.edelbrock.com/automotive_...ers_manual.pdf
Reply 0
Apr 8, 2008 | 06:04 PM
that manual will probably help...I thought the owner told me it was a 650, but that isnt showing up anywhere. is there a place on the carb where i can identify exactly what it is? I have never done any carb work either, how difficult are these to work on? Also where would I begin to decide what i need to adjust??
Reply 0
Apr 9, 2008 | 11:05 AM
There is a 650 CFM in the Thunder AVS series. http://static.summitracing.com/globa...0518061812.pdf , see page 2 for the p/n location.
Reply 0
Apr 9, 2008 | 12:25 PM
alright i will do that, so do you think this kind of thing would be practical for a beginner to do? it kind of seems like it takes quite a bit of experience to be able to know what to change.
Reply 0
Apr 9, 2008 | 01:09 PM
I guess I don't understand why you're doing the spacer.
Going through the manual-described tuning would be a good learning process.
Reply 0
Apr 9, 2008 | 06:02 PM
i decided on a spacer because i thought it would be cool to see if it actually made a difference, because it is pretty simple to make, and because i needed to make something for my class. I really couldnt think of anything better. yes, it would be cool to get that experience. i want to learn how to do it sometime.
Reply 0
Subscribe
