CCC QJet Help
Old Apr 13, 2008 | 09:11 AM
jminton's Avatar
Car: 1985 IROC
Engine: 305 4bbl H.O.
Transmission: WC T-5
CCC QJet Help
When cold starting (after sitting overnight) the engine fast idles for a few minutes at 4500 - 5000 rpm. After a few minutes, I can tap the gas and it will idle at 550 - 600 rpm. Where on the carb is the adjustment for the fast idle?
Old Apr 13, 2008 | 09:46 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: CCC QJet Help
See carb sticky at the top of this forum. Look for fast idle adjustment.
Old Apr 13, 2008 | 09:54 AM
jminton's Avatar
Car: 1985 IROC
Re: CCC QJet Help
thanks, i didn't even think about that.
Old Apr 13, 2008 | 12:30 PM
naf's Avatar
naf
Re: CCC QJet Help
If you get stuck or have a question, we're here...
Old Apr 15, 2008 | 07:44 PM
jminton's Avatar
Car: 1985 IROC
Re: CCC QJet Help
found it, got it adjusted to where it doesn't idle so high cold. what is the recommended rpm while the choke is closed?
Old Apr 15, 2008 | 07:51 PM
Damon's Avatar
Re: CCC QJet Help
On an overnight-cold engine it should settle in around 1300-1400 shortly after startup.
Old Apr 16, 2008 | 11:23 AM
jminton's Avatar
Car: 1985 IROC
Re: CCC QJet Help
thank you very much to both of you. my carb appreciates it!
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
2QUIK4U
Aug 26, 2015 04:40 PM
Street Lethal
Aug 13, 2015 08:28 PM
