Idle mixture screws.
Old Apr 17, 2008 | 05:29 AM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Does anyone know if there's any difference in the diameter of the idle mixture screws on the cc qjets.I found that one of mine had a stripped thread,so i took one out of my old qjet.The stripped one is alloy,and the one from the other carb,is steel.Both the same length and i just wondered if the tip diameter is the same.
Thank's,
Alicat.
Old Apr 17, 2008 | 10:19 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I've never seen a difference between CC screws, but I haven't seen that many. I've never heard of a difference, though.
CC idle mixture screws are fine thread, non-CC are coarse thread. I hope that wasn't mixed up with your carb.
Old Apr 18, 2008 | 04:10 AM
alicat's Avatar
Axle/Gears: Stock.
Re: Idle mixture screws.
Thanks five 7,Both sets are fine thread,and both carbs are cc,one 1985 and the other1983,but as i said one set are steel in a alloy throttle body,and the other set are alloy.The diameter looks to be the same at the tip.I only changed the stripped one.
Alicat.
Fronzizzle
Feb 9, 2017 09:31 AM
amcnellis
Sep 16, 2015 04:16 PM
Rally Smith
Sep 14, 2015 06:59 PM
katrav8
Sep 11, 2015 09:00 AM
IROCtometal
Sep 9, 2015 10:01 AM
