TPI to Carb swap?
Old May 8, 2008 | 10:29 PM
mattheguitarman's Avatar
Car: 91 z28 Camaro, 07 Scion TC
Engine: Soon to be: 383 Stroker
Axle/Gears: Soon to be: 12 bolt, 3.73
TPI to Carb swap?
Hey guys i kno, heres another tpi to carb swap thread but i just need some more specific help..I did a general rebuild on my 1991 350 tpi, medium street comp cam, block honed, crank ground & matched, upgraded rods roller rockers and rings all that stuff, stall converter, but just am not having any luck with it. Now i finally want to totally strip it down and go carb, i really want to go with a tunnel ram set up on it and want to get a good combo that will give me some good power..i also want to run it non cc with a nice msd or something, any help in goin about all this would be great, thanks guys!!
Old May 8, 2008 | 10:40 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: TPI to Carb swap?
get a good edelbrock performer rpm air gap intake, stay away from a tunnel ram unless u are a drag car, they are for high rpm only they will kill your street performance....
Old May 8, 2008 | 11:22 PM
Oh and how about a distributor also
Old May 8, 2008 | 11:40 PM
Car: 1991 Z28 1LE
Transmission: 4l60e
http://store.summitracing.com/partde...5&autoview=sku
Old May 9, 2008 | 01:25 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
eh i would not go that route, i converted mine from carb to TPI but to each his own.
Old May 9, 2008 | 10:18 AM
Haha thanks for the help, nah im just gutting it all out and putting a nice engine in there, just any help u can as far as heads and carb combo. I was thinking a edelbrock rpm air gap intake with a holley 600cfm carb and the mallory 3 port afpr, what heads would u think would work the best with that app with a medium street/strip comp cam?
Old May 12, 2008 | 01:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Heads & intake:
http://www.sdparts.com/product/SD806...RPMAirGap.aspx
Carb:
I'd go at least a 650 CFM Holley double pumper.
Torque converter:
You'll need more than stock stall if you go with a bigger cam. 2500-3000 most likely for a typical street/strip combo.
Don't forget you'll need to get a geometry corrector bracket for the carb throttle arm, and provide some means to lock up the torque converter clutch.
Old May 13, 2008 | 02:15 PM
Ok 650 cfm..check, and yeah i installed a 2400 stall torque converter, should i go any bigger? And also with my stock 350 heads, what would u recommend like a port job and keep the stock heads, or get new ones with a bigger cc, thinking like the chevy vortec heads?
Old May 28, 2008 | 07:35 PM
88tpi350's Avatar
Car: 88 formula
Engine: 350 goin carb
here is what i did... save 2k and get a top end kit. edelbrok has one for 1800 claims 430hp. comes with all you need minus carb. as for stall id say get at least a 3k, i have the gm perfomance parts hei distributor, all works well. love it.
Old Nov 13, 2008 | 09:19 AM
SKYNOVERYA550's Avatar
Car: 88 iroc z28
Engine: 355
Transmission: Bowtie stg 3
Axle/Gears: 4:11
when you do a swap, i know you need a hei dist ect... but do you have to run a msd box? i was told you can make it work without. by changing to a 4 pin module. any thruth to this?
Old Nov 13, 2008 | 09:38 AM
five7kid's Avatar
No. You need the mechanical and vacuum advance mechanisms, unless you get the programmable MSD box.
Old Nov 15, 2008 | 12:22 PM
Car: 88 iroc z28
Engine: 355
Axle/Gears: 4:11
but it would obviously run better with a msd like a 6AL correct?
midge54
Jan 29, 2017 07:00 PM
gta90
Sep 15, 2015 04:00 PM
86IROC112
Aug 17, 2015 02:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
Sanjay
Aug 12, 2015 03:41 PM
