Throttle cable help (with pics)
So iv orderd about 5 diffrent Throttle cables and nothing seems to fit right.
the only thing i have done is swap from TBI to carb and im running a a braket that bolts to the the back of the carb stud everything else works great but the Throttle cable here is whats wrong with my stock TBI cable (pic)
its binding....
the other cables i have had...
the bottem cable has the clip i need the other is a cable i havnet returned
and is a tad to short and doesnt fit the firewall becuse the clips to small and the round part goes thorw the whole in the firewall
does anyone know if theres at least a carb cable with the firewall clip i need? or have parts numbers? any help would be great
its binding....
Transmission: 4L80E/4L80E
A stock '82-'87 carb V8 cable should work.
I've got one I'm not going to be using, but it's missing one locking tab on the engine bracket end.
Re: Throttle cable help (with pics)
That is a 85 v8 carb cacble from a thirdgen (the short one above)
the longer one was my stock tbi cable and have the end i need that clips to the firewall the other one (carb cable) falls into the hole thats in the firewall
Car: 1991 z28
Engine: 5.7l TPI
post a pic of the other end...maby you can try to make something to keep it from falling in the firewall
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
one approach would be to make a clip for the firewall, and the clip would then keep the cable from backing through the firewall. I wonder if maybe the metal clip that commonly comes with a stock air filter breather would work. I mean the ~3 inch X ~ 1.5 inch plastic holder that is used with a stock carb air cleaner comes with a metal clip, I this clip holds the plastic air filter breather "cup" in place.
Car: 1991 Camaro RS
Engine: 355
Transmission: BTO 700R4
Axle/Gears: 4th gen 3.73
I had a problem with the BTO TV cable bracket. I had to cut a piece of steel and move the bracket where the throttle cable snaps in.
9192camaro
16
Feb 3, 2019 12:21 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
