carb rebuild
carb rebuild
alright heres my situation. i have an 84 z28 with a 350 out of a 91. it still has the carb from the 84 305 though. its a 4 barrell. so my first question is what carb is it? 2nd question is how hard would it be to rebuild, and where could i get a kit to do it? any help is appreciated. thank you!
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Re: carb rebuild
I just rebuilt one, first carb in ~15 years and it works
It was kinda hard but not that bad. Here's what worked: go to parts store and 1) buy gallon of stuff to soak your parts in (might also use an oil changing pan to soak large parts in for 24 hrs or so). I used Berryman's gallan can, was ok, left a thin oil film that could preserve parts. you could spray off every bit of carb soak/cleaner left by using Berryman B12 spray can. 2) order a carb rebuild kit and float. look for number stamped on your carb: 17084#### and parts can order right one. Sorenson was ok, will use AC/DELCO kit next time. instruction page lists parts in order to take off and put on in reverse order. 3) you might want to buy a books from e-bay (look up Rochester Quadrajet E4ME, that's the carb original on your car). 4) search on this forum for keywords like rochester, ccc, or e4me; I learned a lot that way. 5) at parts store buy a little metal ruler that goes down to 1/64th of an inch. 6) take your time and you'll probably need to make a parts stand for your carb. 7) after building a Haynes book can guide you through tune up steps in chapters 4 and 6, but not on rebuilding an E4ME, oh ya 8) take pictures of your vacuum lines and label them to help replace them just like they were first connected
It was kinda hard but not that bad. Here's what worked: go to parts store and 1) buy gallon of stuff to soak your parts in (might also use an oil changing pan to soak large parts in for 24 hrs or so). I used Berryman's gallan can, was ok, left a thin oil film that could preserve parts. you could spray off every bit of carb soak/cleaner left by using Berryman B12 spray can. 2) order a carb rebuild kit and float. look for number stamped on your carb: 17084#### and parts can order right one. Sorenson was ok, will use AC/DELCO kit next time. instruction page lists parts in order to take off and put on in reverse order. 3) you might want to buy a books from e-bay (look up Rochester Quadrajet E4ME, that's the carb original on your car). 4) search on this forum for keywords like rochester, ccc, or e4me; I learned a lot that way. 5) at parts store buy a little metal ruler that goes down to 1/64th of an inch. 6) take your time and you'll probably need to make a parts stand for your carb. 7) after building a Haynes book can guide you through tune up steps in chapters 4 and 6, but not on rebuilding an E4ME, oh ya 8) take pictures of your vacuum lines and label them to help replace them just like they were first connected Thread
83 Crossfire TA
Sep 8, 2015 12:06 PM
