Electric choke wiring
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
Im in the process of finishing up my motor swap in my car. I need to wire in the electric choke. But what can I tap into. The carb is a holley, the manual said to tap into the wiper motors power. I know it needs to be switched 12v and taping into the wiper motor would be easy but what wire can I use. The car is an 89 and was origionally TBI. I cut all the uneeded wires out of the harness also. What has everyone else used?
Matt
Matt
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
Re: Electric choke wiring
i did the same swap. i used one of the switched wires that ran up on top of the motor. works for me. i don't know about the wiper motor. mine was right there. where did you cut the wires? at the main plug or up on top of the motor?
I cut them back to the main plug for the ECM. I had the harness out of the car when i did it.
matt
matt
Car: 1989 RS Camaro
ok. i ran my wires and then cut back. you could run a wire to the switch power. of i can check my car to see if there is a switch power on the wiper motor.
I looked at the wiring diagrams but couldnt pick out which wire was power for the wiper motor. I figure that would prolly be the easiest or atleast closest power wire. The length that holley gives is just right to run to the wiper motor.
Matt
Matt
Car: 1989 RS Camaro
my car is in my garage. give me a min. i will check them with a test light.
Your the man! Thanks alot. Where abouts in CT are you. Ill have this car up and runnin in a week or so, always lookin to cruise with another thirdgen
Matt
Matt
Car: 1989 RS Camaro
about 10 mins from foxwoods. we just had like 4 car shows out here this past weekend. some nice 3rd gens around here. hell yea. i am having a prob with mine but should be fixed soon. what fuel pump/ fuel regulator are you running?
Stock TBI pump with a mallory 4309 reg. Right before i started the motor swap i had the rear out. Shoulda done a pump then. O well. You?
Car: 1989 RS Camaro
mallory 4309 with a holley blue. best thing i did was ditch that in tank pump. my only prob now is i cannot get my fuel press below 9 psi. used to but not now.
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
2se, camaro, carb, carburator, carburetor, chevy, choke, diagram, electric, electronic, gen, holley, location, tbi, wiring
