minor holley tuning issues...
Old Jul 5, 2008 | 02:46 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
holley 3310-1 780 CFM Vac Secondaries.
i had the idle speed, float levels, enrichment needles, etc. all in line yesterday.
i decided to swap the power valve to a 10.5 (according to sofakingdom's writeup at the top of the page) and have had a couple of issues.
1. under heavy throttle (in park) i am getting an occasional backfire through the carb.
would that be a sign of a rich or lean condition?
2. now when i hook up my vacuum gauge to the carb, it starts to bog a little bit. is that normal? yesterday (with the 6.5 PV) i was around 15-17" hg.
as far as the retuning with the new powervalve goes, i didnt do much because of the backfire (happened only twice in a 10 min period). i just wanted to double check a few things.
Old Jul 7, 2008 | 11:00 AM
impaled's Avatar
Re: minor holley tuning issues...
ok. i have most if it resolved.
the one thing that i forgot to mention is that i put some more fuel in (i thought i would give 87 a try since i have no idea about the compression, etc. i put some lucas octane booster in and no more backfiring through the carb, so i guess i will be running 89 or 93, (or i might back off the timing a little bit) when i am not going to the track.
the thing that i dont understand though is that the engine still bogs when i hook up the vacuum gauge.
any explanation for that?
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
ULTM8Z
Sep 16, 2015 09:15 AM
gta892000
Sep 16, 2015 12:40 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
