best hangers & rods for MPG
1 Post
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
What hangers & rods work well for higher MPG?
The carb is set to factory settings.
It's running good using a "G" hanger and "CH" rods right now.
Response is good/smooth, just wondering how to tweek for better/best fuel economy.
Thanks -
Thanks -
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Rods & hanger don't influence MPG. If you're employing them, you're gulping gas.
1 Post
Car: 87 Camaro Z-28
Re: best hangers & rods for MPG
ok, what hanger(s) & rod(s) would help open up faster, if I wanted to get ready for the track?
What he means is that secondary rods and hangers don't affect fuel economy since the secondary side of the carb isn't feeding any fuel into the motor until you open it up- beyond about 1/2 throttle or so when the throttle linkage begins to open the secondies.
Don't know the specs on your motor, but if you've got a set of CH rods in it now I think you'll like the improvement that a set of DR (305 HO rods) gives you. Your G hanger is fine.
1 Post
Car: 87 Camaro Z-28
thanks - got that down for an option someday.
reason for asking was remarks in Roe/Ruggles books made me wonder if there was in fact a more lean set-up for hangers/rods (lean set-up not specifically talked to in books). I see the big point: using secondaries = more fuel = lower MPG.
1 Post
Car: 87 Camaro Z-28
lol I could not figure it out from the books. stick w/ the G hanger as well?
sorry to steal this thread if i am but mine bogs if u punch it and will almost stall out until i let out i think this means i am lean i have stock hanger and rods i think the hanger has an I or an H lol but how do i tell what the rods are and what should i switch to thanx
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
sidebar...
what rods came stock on a 1987 LG4???
different from other years??
ok new question, i have never actually pulled mine yet, its probably real lean though... but how would i know what rods and hanger it had??? is it printed on them??
1 Post
Car: 87 Camaro Z-28
yes, I can tell you about the stamps into the metal. Hangers are stamped right on top w/ letters ranging from B to V & rods are stamped w/ 2 letters.
What I don't know is if a G hanger is considered lean, and if not what's a better choice for a commute to work, and overall if hangers and rods are matched (presume they are but don't know principles) - hopefully we'll get some schooling here shortly
Car: Pontiac
Car: 1983 G20 Chevy
Transmission: 4L60
My Cadillac 307 vin 9 had DDs on a K! Knowing they wouldn't cut it on the stock 180 HP 307, much less the 300 hp 403 that was going in its place, I swapped to a DA rod on a G hanger and all was great, even on the stock 307.
http://www.hioutput.com/tech/qjetrod.html
Keep in mind that the stock opening under the secondary rods is .1360 on all Q-Jets and is not easily changeable. The smaller the end of the tip (90* airvalve opening #) the richer the WOT A/F ratio will be. You can have several tapers using the same power tip size. The difference here is small but substantial. The difference in taper along with the hanger is how you adjust the mid-range air fuel ratio. The small end of the taper is how you adjust the high rpm air/fuel ratio. Also keep in mind something like my stock 307 is only going to slighly open the secondary air valves and only going to pull so much air/fuel into the engine. A stock base 305/307 may only pull 30% of the air valves opening where a built up 400 may pull 70%+.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
DD's are FAT!!! (lean!)
A bog going into the secondaries is usually caused by a misadjusted air valve. Set the tension right.
If you go to a different letter hanger (that basically tells when it STARTS to raise the secondary rods), that'll make it go rich SOONER. HOW RICH is defined by the rods.
It's a tuning tool. We can't sit here and tell you what you need, try a bunch and see what runs best.
Car: 1983 G20 Chevy
Transmission: 4L60
DDs are the LEANEST factory Q-Jet rod made. They came in most of the 140ish HP cars like the factory 307s, LG4 305s, and 4.3s. I know for a fact that my Cadillac could not get out of its own way with the DD rods and the 1/2 blocked secondary air valve.
All rods start out with very similar closed (0* air valve opening) sizes. As the air valves open the rods then taper toward the smaller power tip end. The power tip end size varies depending on the rod. The overall taper of the rod also differs depending which rod you have. You can have two drastically different rods with the same power tip size.
You can also fine tweak the A/F ratio by the hangers. B-V where B is richest by pulling the rods out the soonest and V is the leanest with the latest openings. DRs on a F/G are a good place to start for most builds.
Years ago Hot Rod magazine built a Junkyard jewel engine running a Q-Jet carb. They took a mid 70s 350 and put 083 TPI heads and a mild comp cam in it. The engine made 320 FWHP using a DR rods on a T hanger (13:1 A/F ratio) and 32* total advance @ 3,600 RPM. Proof you don't have to go huge on the rods to make good power.\
http://www.corvetteclub.org.uk/files...une_a_qjet.pdf
1 Post
Car: 87 Camaro Z-28
Thanks everyone, the tips and links are great! I might try a K or similar hanger if I happen to see one ... on the way to trying to create the ... lol ... commuter dream car!
Car: 1986 Pontiac Firebird S/E
Engine: 305 carb'd V8
Transmission: 4-speed auto
Axle/Gears: Stock
So what's the best combo for power?
Car: 1982 Trans-Am
the one that keeps you in the right AF ratio across your power band.
It's a tuning TOOL, we can't tell you which one to get for your engine. That's like asking what the right belt size is.
Axle/Gears: Stock
Not really. You could simply say I don't know and that would suffice or you could also give different examples for different setups.
For example, mine is a 305 with just headers and a 2.5" exhaust all around with a high flow cat. So what would be a good setup to use to maximize what I got?
Car: 1982 Trans-Am
I could rattle off examples until i'm blue in the face, and it wouldn't do you any good at all.
I don't know your altitude.
I don't know your driving style
I don't know your engines modifications
I don't know how many miles are on the engine
I don't know which headers you have, or if you have single or dual exhaust
I don't know which rods/hangers you have available to you
So since I know so very little, i'll give a complete wild guess, and satisfy your thirst for tangible information.
Use a K hanger and DR rods, stock for an L69. How's that?
Car: 1983 G20 Chevy
Transmission: 4L60
1 Post
Car: 87 Camaro Z-28
Cliff Ruggle's book lists 3 combos for power, depending on engine, etc. set-up.
I'm going to try different hangers for fuel economy. Cheap experiment.
Axle/Gears: Stock
b) Ok, I like to DRIVE my car. I like power and acceleration. I don't however go 60 down a residential and more then 90 on the highway.
c) Yes you do, I told you only headers with a highflow cat and the exhaust is 2.5" all around.
d) approx. 154,000
e) Headers are from Summit. Y-pipe is also from Summit. High flow cat' is from Magnaflow. Stock 2.5" setup from the cat back.
f) That, I will have to check and get back with you on.
Car: 1983 G20 Chevy
Transmission: 4L60
a) Read my location. Thats no more then 12ft above sea level tops.
d) approx. 154,000
d) approx. 154,000
Car: 1982 Trans-Am
Thank you Fast! I was just trying to make the point there.
I don't have a magic calculator that I can put in all that information, and spit out a recommended setup for you ( although that would be nice...)
You need to tune it yourself.
Axle/Gears: Stock
Yeah but come on. At least Fast lent a little more sense of direction.
That's all I was looking for anyway.
Car: 1982 Trans-Am
My bad. I'm just getting lazy
https://webdisk.ucalgary.ca/~jmknopp/public_html/
Read the top three files (the .doc files). They are excellent q-jet tuning articles.
If in doubt, use Fast355's advice though, his was specific to cc-jets, where my articles are specific to non-cc (well, Lars' articles, but i'm hosting them so...)
Many of the concepts are good for both carb styles.
LT1Formula
10-08-2015 08:34 PM
skinny z
10-05-2015 06:23 PM
