Convertor lockup.
Old Jul 8, 2008 | 04:58 AM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Convertor lockup.
I know what i need to do to the tranny if i remove the ecm.As I only drive the car occasionally,could i leave the fix for a bit or is it bad to drive at all,with no lockup,in regards to slippage.
Alicat.
Old Jul 8, 2008 | 09:30 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Convertor lockup.
Do it as soon as possible, and avoid cruising for long distances in 4th until you do.
Are you sure your car has an ECM?
Old Jul 8, 2008 | 09:35 AM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
I'm kinda jackin this thread, but i got a 200c tranny, and i removed the ECM, how do i get the converter to lock up? Is it those wires Hanging off of it? where do they go?
BTW, why is this posted in carburetors?
Old Jul 8, 2008 | 09:36 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The 200-4R and the 700R4 TCC's are controlled the same way, the only difference is in the physical arrangement of parts inside the valvebody.
Keep an eye on this thread:
https://www.thirdgen.org/forums/tran...ml#post3815689
It's in carburetors because only carbureted setups don't have a computer to take care of such things.
Old Jul 8, 2008 | 07:01 PM
alicat's Avatar
Axle/Gears: Stock.
Thanks.Yes it has a ecm,I dont mind the cc system,i'm just trying to tidy up the engine bay a bit.Just difficult with everything in the way.I've already have the non cc dist and a standard stage one Qjet for if and when i get around to doing the swap.So I could get away with short distance driving,for testing purposes,before I did the tcc.
Alicat.
Old Jul 8, 2008 | 07:36 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You could, but it's easy enough to at least wire a switch through the ALDL like in the tech articles.
Old Jul 9, 2008 | 12:46 AM
alicat's Avatar
Axle/Gears: Stock.
That could be the best way to go.I dont like to change too many things at once.Just makes it harder to track and solve issues.
seiplentz
Aug 19, 2019 06:02 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
Nervous2
Oct 8, 2015 10:53 PM
1nastygta
Sep 24, 2015 08:58 AM
Eric-86sc
Aug 24, 2015 09:01 PM
