Engine Idles - Ac
Engine Idles - Ac
Anyone know why when I Start the car It will start up at around 10rpm then If I let It sit it will drop down to 7-8 then 4-5 and chug and fight and then work itself up but then eventually stall ? I mean If I am at a stop light I have to feather the pedal or It stalls.
Also anyone know anything about AC? I bought a new AC belt and put 3 cans to recharge it but I can't get anything to come out of the vents ? I can see the compressor turns on and works fine ? Any Ideas ?
You think its the TPS sensor for the Idle ? Because I took the TPS Sensor out and It went all the way up to 15rpms but never died ?
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
Re: Engine Idles - Ac
i assume since you posted on the carb board, that you are carbed. stock computer controlled carb (E4ME QJET) or do you have an aftermarket carb on there? if so what brand, model, CFM, what style choke?
it is likely a tuning issue.
