Replacing TPS and Solenoid?
1986 Camaro 305, 5 speed.
Starting a rebuild on the stock cc quadrajet with an Echlin rebuild kit (NAPA).
Question is: Can I replace the TPS and mixture control solenoid later and/or with the carb reinstalled or would the TPS and mixture control solenoid have to be replaced during the rebuild?
Thanks for any info.
Car: 84 T/A
Engine: 305HOL69
Re: Replacing TPS and Solenoid?
If they need to be replaced, you'll be much less frustrated if you do it during your rebuild/reassembly. Both require the entire top air horn to be removed; why do it twice?
mdtoren
Aug 16, 2015 05:45 PM
