edelbrock to holley hook up help...
Car: 1983 Camaro Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: Strange S60
i have a holley 750dp that im putting on and taking off an edelbrock 650. I am confused about some vacuum lines. there are 3 on the edel but i could only see 2 on the holley. one of the 3 is blocked off. what goes where?
also how do i tell if its vacuum secondaries b/c if i twist the throttle the primaries open but not the secondaries and i dont know if i just didnt put a rod on...
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: edelbrock to holley hook up help...
It can't be both a DP and have vacuum secondaries.
Engine: 383
ok so then i am missing some linkage if the secondaries dont open with the throttle right?
Engine: 383 Carb
Transmission: 4L60
The secondaries won't open if the choke is closed.
Transmission: 4L80E/4L80E
Sounds like you have a vacuum secondary carb. The link is on the passenger side of the carb, goes up to a diaphragm. There is a link on the driver's side to keep the secondaries closed until the primaries are open.
Check out the sticky in the top section of this forum (Welcome to the Carburetor Forum, etc.). There's a link there to the Holley website that explains the operation.
Engine: 383
ok so i realized that the secondaries will open if i twist them, but only when the primaries are open, and i think it is vacuum secondaries because it has a diaphram.
so is Apeiron wrong b/c it is both dp and vacuum as far as i know...
there are also little pieces like a small spring and a black clip that i dont know where they go... and on the diaphram there is another screw and clip for something but i dont know what.............
any help?
any help?
Engine: 383 Carb
Transmission: 4L60
Can you get the list number of the carb stamped into the choke horn, and/or post a picture of the carb?
Engine: 383
i'm guessing that the choke horn is the flap that the choke opens because the only number stamped that i could see is on that, the number is 388.
do only dp's have dual fuel inlets?
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
no all 4150s have dual fuel inlets my vs carb has two...l
does your carb more closely resemble this one
http://www.holley.com/data/products/...gerNewShot.jpg
or does it more closely resemble this one
http://www.holley.com/data/products/...rge0-4779S.jpg
ignore the finish of them. on the first pic that black plastic piece on the side is the vacuum diaphram. it could be plastic or metal but will be generally the same shape and size in that spot. if you have that diaphram then your carb is a vacuum secondary carb.
Engine: 383
ok then it is a vacuum secondary carb b/c it has that diaphram which would make it a non dp, ok so now that i know that, the secondaries arent opening and i dont think there is a vacuum source to that diaphram, where would it connect to? would the secondaries open if i rev it by hand at WOT?
Car: 1991 Z28 1LE
Transmission: 4l60e
no u wont see the secondaries open reving the motor, there has to be load for them to open and u dont hook up any vacuum for it, its self containded in the carb...
Engine: 383
oj, also there is a vacuum line rinning to the electric choke, but the edelbrock was blocked off, should i do the same with this one?
what should i be adjusting with this to get it tuned? i already adjusted the float bowls, i think they are good. what else?
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
Idle mixture screws should be next after setting the floats, adjust for the best vacuum at idle, then set idle speed
if its electric choke i dont know what vac line your referring to but there should just be a ground and a hot wire to your ignition, and you adjust it by turning it and usually you can use a pencil to set the gap or is that for an eldebrock i cant remember.
theres gonna be a vac line for your pvc or brake booster and maybe a full manifold and a ported one for your distributor.
Engine: 383
i dont have a vacuum dial but i am getting it dyno yuned tuesday, should i have him do it there if he can or is it not that important?
maybe its not vacuum but there is a metal nipple going into the choke assembly and a line came with the carb.
Car: '89 IROC-Z
Engine: 355
yeah its pretty important you can go by sound too (engine rpm) and tune for highest rpm
Car: '89 IROC-Z
Engine: 355
Pac J
May 17, 2020 10:44 AM
sreZ28
Oct 22, 2015 08:21 AM
Night rider327
Sep 25, 2015 04:47 AM
